Question about Glidden Premium Paint. 8-oz. Wild Truffle Interior Paint Tester GLN44
What paint color can i use in red to make it darker
It is called red roes bounguent and it is a real bight red on my wall. but when it is on the color card it is darker
Old elec. wiring is showing verdigris ( grease ) on the plaster surface! what do I seal the surface before painting?
ask your "local paint store" manager first...
if they do not know, I suggest washing down the wall, scratching it lightly with sandpaper after it is dry, then apply an alcohol based primer to seal the grease. I would then prime with a good latex primer before final coating. If you are painting pastels, or very dark colors (red, Blue, Black), tint the primer toi as close to the color you want.
Good luck
Neil
Sep 23, 2014 | Tools & Hardware - Others
Tip
Tips for Picking Paint Colors: If you don’t think you’re a very creative person...
      If you don’t think you’re a very creative person but want to paint your house or even just a room, you might be feeling overwhelmed by the challenge of picking a color! Don’t panic – here are some top tips for helping you choose a great color scheme for your painting project.
      1.Use the color wheel. Don’t be afraid to take a look at the color wheel – it’s not just for decorators to show off to their customers with. You can ask someone in a paint shop to explain to you how primary, secondary and tertiary colors work together (or sometimes against each other).
      2.Try and decide what kind of ‘energy’ and brightness you want in the area you are painting. Is it a lounge that you want to be cosy? Or a bedroom that’s modern and bright? It really helps to visualize the end result.
      3.Are you hoping to your space look bigger or a large room cozier? If so, you can use color to help you. Small spaces will benefit from pale, cool colors and larger areas can be made to feel more intimate with warm, darker colors.
      4.Watch out for lighting issues. Natural daylight shows the color in its truest way whereas fluorescent lights cast more of a blue tone over the overall color. So make sure you pay attention to the lighting issues around the area you are painting.
      5.If you want to play it safe you can always go for neutral colors. These are colors that don’t stand out but you can use furniture and decorations to really add the splashes of color while keeping the walls in more subtle neutrals.
      Have fun! You can always paint really small areas to see how it looks on the wall. And try to be bold – you’ll probably be surprised with how good it looks.
on Dec 25, 2013 | Crafts & Hobbies
My paint is too light want to change from light purple to dark purple
You can go to your local store that sell s paint and buy a darker tint for just a few $$$
Aug 18, 2014 | Valspar Corporation Valspar Signature...
I am home this weekend and I decided to paint my living room. Is there an amount of coats that you are needing to put on the wall? It has been a while sense I have painted. I heard maybe about 3 to be...
if the existing paint is a light color and you are doing the same color, then 2 coats should suffice,. Painting it darker, I would go 3 coats, painting it lighter, you may need to go more than 3 go to harbor freight tools and buy some plastic drop sheets, masking tape {blue} and some cheap brushes and roller and tray, turn on some tunes and a glass of wine, enjoy the "me time" depending on the quality of paint too will determine the coats needed, ask your home depot guy. behr brands are good cover paints. good luck have fun.{ps..wear some old clothes}
Oct 15, 2013 | Corel Paint Shop Pro 9
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
May 20, 2013 | Home
I have a red coat rack in my daughters room and it clashes with the pink walls, do you have paint suggestions?
As an interior designer, I always recommend using gender neutralcolors in kids' rooms. I suggest thatyou paint your coat rack a muted color like grey, beige or white. The lighter the color the less likely it isto be mismatched with the rest of the room.
May 29, 2012 | Home
1974 yamaha gt 80 paint codes
if you look up the part # from oem supplier and get the orginal tank number the last 2 digets are the paint code. A 1974 yamaha GT80 red tank is part # 367-24110-00-63. This is called brillant red. O63 is your paint code #.
Jan 02, 2012 | Motorcycles
In the middle of screen the is red area next to the bottome of the picture,and also the picture is not bight like it used to be seems like everything is darker.
Bad optical engine. Your repair cost will exceed $1200 since this part is so expensive. Part# UX25302
Bill W
integrityhomeworx.com
Mar 22, 2011 | Hitachi UltraVision CineForm 55VG825 55"...
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    Glidden Premium Paint. 8-oz. Wild Truffle Interior Paint Tester GLN44 Logo
    52 people viewed this question
    Top Glidden Premium Tools & Hardware - Others Experts
    Bill Boyd
    Tom Chichester
    Are you a Glidden Premium Tool and Hardware - Other Expert? Answer questions, earn points and help others
