Question about Cygnett Lavish Connect Folio Stand Case With Bluetooth Keyboard For Ipad 2 And Ipad 3 - Sandstone
The top row of letter keys have stopped working on my cygnett lavish ipad keyboard...this is the second time this has happened, I got the first unit replaced and it has happened again. Any ideas about
I can get the T and Y keys to respond only...is this a fault with the product?
  • Not me Sep 19, 2013
    I have the same issue. Looks like a bad batch got through? Q to P stopped on mine. Asking for refund as it's not of acceptable quality or fit for purpose.
I need my iPad to be in English on my FB
Hi
On the keyboard there is second from the left in the bottom row a key where you can change languages.
26164510-ffgxqzzpvvdxlnjmxorl24rb-4-0.jpeg You can also get smilies by using the same key. When you want to go back to the alphabet push the abc key
Apr 15, 2016 | Apple iPad Tablets & eReaders
Bottom row of letters has died/is suddenly unresponsive. Can this be fixed?
Your touch sensitive screen seems to be broken. This normally means it needs to be replaced completely.
Aug 21, 2015 | Apple Pre-owned A1359 Ipad Keyboard...
Cannot get bluetooth keyboard to connect
Make sure the keyboard does not have a pairing relationship with another device in the room.
If there are any devices listed on the iPad, in Bluetooth settings, tap 'I' and forget Device.
Place the keyboard in pairing mode with a 5 second depress on power from the 'off' or no power state.
Type the keys on the keyboard that the iPad wants for the pair.
Aug 13, 2015 | Apple iPad Air
How do I get the keyboard of my Ipad mini to drop down it is stuck at the top of the page and has split in half
In the lower right of the keyboard is a keyboard key (it looks like an icon of the keyboard). Touch and hold the keyboard key. After a second or so, word choices will pop up saying something like "Dock" and "Unspilt". Touch one of the words. If you want to do both actions, repeat the process for the latter.
Feb 19, 2015 | Apple iPad Mini
How do I capital letters on my apple air ipad key pad
In your Settings app, go to General-->Keyboard and make sure the "Enable Caps Lock" is on (green).
After Caps Lock is enabled, quickly touching the Caps key twice will lock it.
(Directions are for iOS 8)
Feb 16, 2015 | Apple iPad Air
My Anker keyboard won't stay connected to my ipad, and it has stopped working after connecting tomy
Hey...umm sorry about your keyboard not working..What i cant sae is maybe u have a stickey key.
To fix this!
Replace the key on the keyboard.
Wipe off the key if you have maybe spilled somthing on it.
Jul 06, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Forward slash on panasonic toughbook
It sounds like you have a ToughBook with a NON-US Keyboard or keyboard layout. The physical "SLASH" key is the last key on the bottom row above the SPACEBAR row.
It is the key on the FAR right side just to the left of the right-side
SHIFT key. Make sure in the taskbar that the EN sign is shown
(on the bottom right side of the screen next to the date/time.
If it is shown FR or ES then your keyboard is in French or Spanish.
You can try to use the ALT+SHIFT key combination to toggle
the FR or ES back to EN (English). If not, then you must
ADD the English keyboard in the Control Panel under
Regional Settings (Clock, Language and Region in Windows 7).
Under Keyboards Click "keyboard" then Click "add" then
choose English (United States), Keyboard then US (only).
That is it. Make sure you select US as "Default" and then you
won't have to go thru all this ever again.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989.
Apr 28, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
Lost charger for keyboard
You could go to a computer shop and ask if they have any in there recycle bin. I did this for my phone charger and the guy was happy to help me.
Apr 02, 2014 | Cygnett Lavish Connect Folio Stand Case...
Zagg keyboard Will not work after connected by Bluetooth in ipad2
I have a Zagg keyboard for my iPad mini. I found the same thing happened but then realized it only works in most apps, not all. For example it doesnt work when typing in a password in settings. Try you keyboard in an app like notes. Also make sure you haveheld down the power for long enough that the light is red for 5 seconds.
Sep 28, 2013 | Apple iPad 2 Wifi 16GB
How do i get my keypad back to normal on my ipad
You have put the keyboard into split mode. You can split the iPad's keyboard in two by either tapping and holding on the 'toggle keyboard' button on the lower-right, or simply pulling the keyboard apart at the middle.
You can put it back to normal by pinching the keyboard back together or by tapping the button on the lower right.
Hope that helps!
Oct 19, 2012 | Apple iPad (16 GB) WiFi Tablet PC
Cygnett Lavish Connect Folio Stand Case With Bluetooth Keyboard For Ipad 2 And Ipad 3 - Sandstone Logo
134 people viewed this question
Top Cygnett Tablets & eReaders Experts
Are you a Cygnett Tablet and eReader Expert? Answer questions, earn points and help others
