Question about Sony Cyber-Shot DSC-H70 Digital Camera
Sony cyber shot dsc-h70 e:91:01
I have tried to look up an answer but I cant seem to find any that work. I have removed my battery and reset the camera back to factory settings but nothing works. I keep recieving this error message and the flash will not work.
debbily
  • 101 Answers
SOURCE: sony cyber-shot DSC-H1 promlem turning on camera
I would.
Posted on Oct 16, 2007
SOURCE: hi I have a sony cyber
I had the same problem, and i tryed everything, even opening
the camera and see if any visible damage on any part (nothing), so
when i try initializing again ( menu>setup>option #1), right after the
"OK" over reseated date, i went to the Flash Button, and turn it off
and at least the annoying flashing error is not there - that means it is
software error, because all flash functions work till it detects that
has ans error wile charging/loading the flash. Hope it helps.
TENFERRE
Posted on Feb 04, 2009
mcomijohns
  • 477 Answers
SOURCE: Flash won't work and flash setting cannot be changed from menu
This is eather caused by a bad flash circuit or a bad mainboad. Repair cost around 65.00 to 75.00 to repair.
Posted on May 25, 2009
ripleymojica
  • 643 Answers
SOURCE: My Sony Cyber-shot DSC-W200 flash has stopped working and when I try to reset it it tells me that flash cannot be reset. What can I do?
its circuit error need to replace flach unit
Posted on Jun 01, 2009
pauman
  • 248 Answers
SOURCE: error message E 91 01
flash error for sony cybershot dscw55 ERROR CODE E:91:01 1st go to SETUP MENU then select the toolbox icon 1 then select "INITIALIZE" press ok, master reset then it goes back to normal
(DOWNLOAD & SAVE PICTURES BEFORE MASTER RESET AND KNOW THAT YOU WILL HAVE TO SET UP TIME&DATE)
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Posted on Jul 06, 2009
Built in flash on Sony DSC-F717 will not open up. Have reset and checked all settings.
BAD battery !!The high quality Rechargeable Sony Cyber-shot DSC-F717 Battery [Non-OEM], It can provide extended power for your Sony Cyber-shot DSC-F717 digital camera, this battery is made specifically for your digital camera and to meet or exceed the original manufacturer specifications, we will ensure optimum performance saving you time and money.
Sep 04, 2011 | Sony Cyber-Shot DSC-F717 Digital Camera
Power button stuck down on my sony cyber shot dsc s600
Possible that this is a mechanical failure and the switch is broken or out of place. Remove the battery and check the charge, if this seems fine then replace and tap the camera upside to see if the buttons resets.
If not the camera must be taken out, try to open ONLY if you have the correct tools and do not try to open otherwise to damage the unit.
Best option is to take an opinion from Sony for estimation.
Jun 25, 2011 | Sony Cyber-shot DSC-S600 Digital Camera
I cant get my camera to turn on. thanks for your
Fist charger your SONY Cyber-shot DSC-W120 battery and clean the connect place of the battery and camera. Please make sure that the battery has been charged by the Sony Cyber-shot DSC-W120 charger. Li-ion batteries life is about 2-3 years, and if you have stored your battery with no power for a long time, the battery maybe has been damaged. When store Li-ion batteries you should charged it at about 40% first.
May 06, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cyber-Shot DSC-T5 Digital Camera My camera will not turn on
1. Please make sure that you're using the fully charged battery.
2. Try resetting the Camera. To reset the Camera, remove the battery from the Camera, press and hold the Power button for 30 seconds and then, reinsert the battery.
3. Please make sure that you're using the compatible battery with the Camera.
4. You may also try using a different battery to check whether the issue is with the battery.
Jan 09, 2010 | Sony Cyber-Shot DSC-T5 Digital Camera
PROBLEME DE FLASH DE CYBER SHOT DSC-R1 E:91:01
Reset the camera by removing and replacing the battery then (what they don't tell you in the manual) Turn the camera on and press the reset button (inside the memory card compartment) After pressing the reset button, turn camera off then on again. All these steps may seem redundant, but I've had very good results using these steps.
Dec 26, 2009 | Sony Cyber-Shot DSC-R1 Digital Camera
Sony DSC-W55 Access Message - lenses going in & out automatically
Please remove the Battery from the Camera then reinsert it after two minutes. Make sure that the Battery is fully charged. if menu options are accessible on the Camera then reset it to the original factory settings. Please follow the steps that are mentioned below to reset the Camera to the original factory settings:
(i) Please turn ON the Camera.
(ii) Then use the control button on the Camera to the select the Setup (setting) option.
(iii) Next, select the Setup1 option then "initialize".
Performing the above mentioned steps will reset the Camera to the original factory settings. If the issue persists then service will be required.
Jul 13, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
My cyber shot dsc w5 wont power up unless I want to view previous pics. What do I do with it?
I had exactly same issue with mine w17 and tried so many ways to fix this. Was even ready to buy some new camera instead of this Sony dsc w-17 but then found a way of resetting camera in such way: powerdown and take batteries out. Then hold "power" button for 30 seconds, release and repeat couple of times. It helped
Also if it won't work try contacting Sony online chat support - they seem to be helpful.
Jul 02, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Sony Cyber-Shot DSC-H70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
