Question about D-Link AirPlus DI-614+ Wireless Router
Can't access D-link DI-614+ as admin
Cannot access as admin after hard reset, using ip 192.168.0.1 with id of "admin" and blank (" ") as password.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Direct from the D-Link FAQ's
This reset procedure applies to the following devices:
DI-704  DI-704P  DI-713  DI-713P  DI-714P+  DI-804HV  DI-808HV
  • Step 1 Power the unit off by unplugging its power adapter.
  • Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
  • Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
  • Step 4 Watch the lights on the front of the gateway. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, recycle the power on the gateway.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure. The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
The following reset procedure will completely restore the default settings on your D-Link device including your password. This procedure applies to the DI-514, DI-524, DI-604, DI-614+, DI-624, DI-754, DI-764, DI-774, DI-784, DI-804V, DWL-700AP, DWL-800AP+, DWL-900AP+, DWL-1000AP+, DWL-2000AP, DWL-2100AP, DWL-6000AP, DWL-7000AP, and DWL-7100AP.
  • Step 1 Locate the reset pinhole on the back of the unit.
  • Step 2 With the unit powered on, press and hold the Reset button.
  • Step 3 Hold the Reset button for about 10 seconds.
  • Step 4 Release the Reset button.
  • Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
  • Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
The default user name for most D-Link devices is admin and the password is left blank.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
How do I access the router control panel?
The factory default User name is admin and the default Password is blank (empty). It is recommended that you change the admin password for security purposes. Please refer to Tools>Admin to change the admin password.
You need to download the user manual. ftp://ftp.dlink.com/Gateway/di614+/Manual/DI-614+_manual_06292005.zip
May 01, 2011 | D-Link AirPlus DI-614+ Wireless Router
Hello, I can not access the router configuration. The IP address in not the correct one.
If the password has been installed, and you cannot remember it, look for a recessed button usually located by the power input plug and press and hold it for about 10 seconds. Then pull the power out and plug back in (to restart) This action will wipe all settings back to factory. Which means you will have to setup wireless password and any ISP (Internet Service Providor) settings needed to access your service.
Feb 08, 2011 | D-Link AirPlus DI-614+ Wireless Router
What is the Dlink DI-624 default password
Here is a site that will help you most of the D-Link routers: http://www.default-password.info/d-link/
Here is an extract: D-Link DI-624 - all admin (none) - Admin access (HTTP) User (none) - Admin access (HTTP)
Feb 02, 2011 | D-Link Computers & Internet
If I don't have the manual for my D-Link 514 wireless router, do i have to buy a new one since I dont have the password?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 31, 2011 | D-Link DI 514 Wireless Router (DI-514)
How do you put a password on it?
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security enter password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Oct 22, 2010 | D-Link DI 514 Wireless Router (DI-514)
Can't configure dir-600 after enabling access point only
http://192.168.1.1
or
http://192.168.2.1
or
http://192.168.0.1
If you are still not able to access it with above ip then press RESET button for 10 seconds it is in back side of router.Then you can access it with 1 of the above ip.
Jul 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Dont know username and password to access the modem
First connect your router to computer with ethernet cable.
then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then you can see configuration page.
Let me know if you need more assistanse.
Thanks.
Sep 24, 2009 | D-Link AirPlus DI-524 Wireless Router
Can not open wizard
You can reset your router.
To reset your router, use the following steps (from http://technicallyeasy.net/2008/02/how-to-reset-d-link-di-524-wireless/):
  1. Press the reset button [the tiny button on the back of your router, marked Reset] for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset. Follow the steps in Securing D-Link DI-524 Wireless Router to secure your router.
admin username: admin
Default admin username: admin Default admin password: <blank>
Aug 16, 2009 | D-Link (DWL-2200AP) 802.11g/b Wireless...
D-link DI-614 won't reset and the password stays same
For problem that you have posted, you can try doing a hard reset on the device by taking a paperclip and perform a hard reset. With unit on, use a paperclip and hold down the reset button on the back of the unit for 10 seconds. Release it and the router will recycle, the lights
will blink, and then stabilize. After the router stabilizes, open your browser and enter
192.168.0.1 into the address window and hit the Enter key. When the
password dialog box appears, enter the username admin and leave the
password blank. Click OK.
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 12, 2009 | D-Link AirPlus DI-614+ Wireless Router
D-Link AirPlus DI-614+ Wireless Router Logo
1,270 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
