Question about Electrical Supplies
Generator dayton 3w954 will not produce power
Pto generator how is best way to excite it
protek480
  • 1714 Answers
SOURCE: Dayton SU936C generator starts but no power
Check brushes. Must be at least 1/2 " long. Check all connections. To flash field: use 12 volt battery neg. - goes to machine ground. Pos + goes to the pos+ brush, the one that's not grounded. Give it a couple seconds on the 12 volts.
Posted on Aug 05, 2009
harlan301
  • 205 Answers
SOURCE: Had to remove generator section to repair the
i need to know do you have a flat cap on the back if so, pop it off. take a lawn mower battery left side ground right hot touch them for 1 to 2 seconds. if no cap on back us a plug in to the 120 same as before
Posted on Oct 12, 2009
  • 108 Answers
SOURCE: can not excite generator
most generators you can polarize the brushs this is done by using a 12v. battery and a set of jumper cables hook to the battery and touch the brushs with the other ends it doesn't matter whicht side, but before you do all that check the connections at the brushs and see if they are loose or not making a good contact, i do hope that i was able to help you, thank you.
Posted on Jan 08, 2010
  • 1383 Answers
SOURCE: My generator is not producing
Simple way is to use a small battery charger (1 or 2 amp) and momentarily contact brushes (very quick swipe). You must watch polarity. Check your manual; generally the positive brush is the one closest to the bearing. Oftentimes problem is brushes have worn and are not contacting rings. Examine commutator rings for smooth surface. Remove diode board and check for leaking capacitor. If it is split open, burned or swollen replace as needed. Good luck
Posted on Sep 03, 2010
SOURCE: Manual needed for Dayton generator model 3w954.
try to Excite the generator.. TAke a 12 volt starting battery attach a wire lead to each post of the battery and plug the other ends of those leads into the 120v volt out receptacles of The generator while it is running FOR ONLY A SECOND OR TWO.. tHIS WILL NORMALLY EXCITE A GENERATOR THAT HAS LOST THE CAPABILITY TO MAKE IT OWN ELECTRICITY. Disconnect the 12v leads quickly so as not to over charge the battery. GOOD LUCK.
Posted on Jan 01, 2012
Why doesnt my Homelite HG3500 generator not produce power when running?
Try flashing the rotor it has lost it's resideual magnetism through sitting.
Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged.
Feb 27, 2015 | Electrical Supplies
The gt5250 power back generator has stop producing
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Oct 18, 2014 | Electrical Supplies
Brushless generator has stopped producing power ,
My Catepillar generator is producing 400v not 480v
You may have a bad exciter diode, short in rotor/stator check AVR output voltage to exciter also, Ohm exitier stator/rotor
Nov 30, 2012 | Caterpillar Electrical Supplies
Can not excite generator
Jan 07, 2010 | Coleman Powermate Premium Plus 6250W...
How do i excite a coleman sport 1850 generator?
This unit is capacitor excited, simply pull the terminals from the capacitor and apply 12vdc to the the wires for about 1 second. Then plug capacitor back in reassemble and run generator and check voltages. If the rotor magnetism has been restored and everything else is good you should be producing power now.
There is an alternative way to excite back end but it is a little more dangerous. It involves starting the unit and then applying 12 vdc to either of the 120v outlets for less than a second. This is the best way but it is more dangerous because once the back end is excited the outlet will now be putting out 120 vac. So if you leave your 12 vdc source connected too long you will back feed that source with 120vac. What we've learned to do is to have 2 wires coming out of the outlets with the tips exposed then we take our wires with the 12 vdc source and just brush them quickly against the 2 wires coming out of the outlet.
Nov 05, 2009 | Coleman Sport 1850 Generator
Hi I have an eagle power generator (E65DRE) and it will not generate power. All the coils and components are alright. Do I have to (excite) the generator after it has been sitting for a while? Has any one...
Yes, that's exactly the issue. You should run it once a month to avoid this. Generators can't sit for a while or they will loose the charge that excites the coils for producing power
Sep 07, 2009 | Eagle 10000 W Portable Generator
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Electrical Supplies Logo
24 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
