No flame on left side/main valve. Right side lights, flames up
Unit element will ignite,
gas on right valve will ignite, flame up and blow
left valve/gas will not ignite or flame up
Unit then shuts down
Have tried reset and cleaning flame sensor on left side
Does not appear gas is coming out of left side.
Checked valve nozzels, seems clean/clear
The main gas valve is a Honeywell VR8205H 8016 -
at least 15 years old
    Problem Solver:
  • 8 Answers
Try taking out the orifice on the burner that is not lighting and make sure it isn't blocked.
Posted on Mar 12, 2009
PILOT LIGHT COMES ON BUT WHEN YOU TURN THE KNOB TO ON IT DOES NOT LIGHT UP THE CIRCLE PLATE IN THE HEATER. IT JUMPS AND THE FIRE COMES OUT THEN IT GOES OUT.
I'm not sure what unit you are troubleshooting but if the main burner is igniting and that main burner flame is blowing out the pilot flame, it's possible the pilot flame orifice needs to be cleaned. The orifice can get stopped up and produce a weak pilot. And I've seen a pilot lite, but be blown out by the combustion of the main burner igniting. Now you stated IT JUMPS. If you mean the pilot flame jumps, as if it gets large then weak and goes out, then the gas valve is giving you trouble and may need to be replaced.
Mar 09, 2017 | Heating & Cooling
The glow stick lights up; approx30 seconds later, you can hear and smell the gas turn on, but the flame does not start
Depending on the specific unit you have the hot surface igniter (glow stick) may be only for lighting the pilot, which then ignite the main burners. The flame has to be proved before the gas valve opens for the main burners. This is done by the flame rod, which could be faulty in your case. The proximity of the igniter could also prevent ignition. Check that the flame rod is clean and secure. Note. be very careful when servicing gas appliances, and never ever use lighters, matches or any other flame source to light them except for the ignition system supplied by the appliance. These appliances are designed and built with safety devices to prevent ignition when it senses a fault or malfunction. This is all for safety. Do not bypass safety devices, it can kill. Call a qualified tech.
Dec 07, 2013 | Ruud Heating & Cooling
My gas water heater pilot light will not stay lit
Hi Mike,
1stly you have to understand what the pilot light does!
Yes, it lights the flame, but it protects you from gassing yourself!
that is thye main job!
hava a look inside!
In front of the pilot flame, (it might have a double flame... (one flame on the bottom & another on top.) is a curved piece of metal plate. The flame is supposed to heat that plate untill it it very hot! Thenm the plate bends down as it is a bimetyaalivc strip!
This opens the bsaety valve & you can let go.
The flame will noe stay on. If a gush of wind blows the flame out, the strip will cool & the safety valve close, preventing a dead family in the morning.
There is a newer system as well.
Right in front of the flame, is a pointed sensor with it's tip in the flame. . It has a electric cable running to a safety valve. This sensor have to heat up as well. It is a heat battery that activates the valve. See that it did not move!
If it heats up, & the valve does not keep the pilot flame going after a few seconds, the unit has to be replaced!
Safety first!
Andy
Sep 04, 2011 | Water Heaters
Left burner produces a normal blue flame, but the right burner produces a big yellow flame - how can I fix this?
Hi inomura...
Look at the left burner, pipe,air hole adjustment,etc because it is operating good.
You will see a difference to it compared to the on the right.
The right pipe, air hole, or the length the pipe that are iserted in the gas control valve is different from the left.
The yellow flame indicates that not enough air is getting to the flame getting to the right flame ignition point.
The left flame is nice and blue...normal, the right is yellow indicating that not enough air is getting to the flame ignition point...look to see if the air hole adjustment is different than the one on the left...there is something open more or less, improperly adjusted.
Once you have it adjusted properly the right flame will burn bright blue just as it does on the left.
Please take time to rate me
Sep 04, 2011 | Coleman Roadtrip Grill LXE 9949-750
Dryer starts, but does not heat up. Igniter ignites, but no heat. Gas to rest of house is operable.
Thier are 2 possible things causing it not to heat.
1) The flame sensor is bad..if the igniter glows BUT does not go off it will be the FLAME SERSOR that is the problem
2) the coils that open the gas valve are defective..If the igniter DOES go off but no flame it will be the gas valve coils
while i dont know what brand you have their are fairly unuvesal parts for the coils or flame sensor
Part#'s
GAS VALVE COILS 279834
FLAME SENSOR THAT FITS ON RIGHT OF BURNER TUBE WE4X448
FLAME SENSOR THAT FITS ON LEFT OF BURNER TUBE 338906
GENE
Aug 28, 2011 | Dryers
My Rheem Criterion 75,000 BTU furnace has three in shot burners with a HSI located in the right hand side and the flame sensing rod in the left hand side. The only burner that ignites is the side with the...
This is potentially a very dangerous condition. First of all, think of the design, the flame sensor is there to shut the valve off if there is not good ignition on all burners. From what you said, it keeps the first burner on with no ignition to the other two? Do you smell gas when this occurs? There are two problems here, lack of flame cross-over to the left and your flame sensing safety failing. If the valve shuts off in a timely manner, then I would say clean the cross-over slots and verify manifold pressure is correct. The latter is more likely. If the safety is failing and not shutting off the gas valve, the control circuit board is defective. The wire coming from the flame sensor should return to a specific point on the control module and it reads micro amps to detect flame. Furnaces will either have a remote sensor as you describe or use the HSI, but not both. If your control module has been replaced, verify the sensor is connected correctly. Hope this helps and please rate my answer.
Dec 30, 2009 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
I can smell the gas coming through. The igniter, ignites a small flame at the right end, but that is all. The flame does not light the burners. I did look at the burners, they look fine. Could there be...
It's either the flame sensor or the gas valve.
The sensor senses flame and sends signal to the valve, the valve then sends gas through the burner/s.
If it's a thermocouple (looks like thisbefore installed) http://furnaceparts.com/eshop/products/thermocouple.jpg
then replace the thermocouple.
It sits right in the flame pattern and they usually cost less than ten bucks.
Dec 29, 2008 | Weber Genesis Silver B Grill
Oven Burners not lighting completely
It's the igniters. They increase in resistance as the elements age and decreases the current required to heat the spring element in the gas valve.
Replace both igniters.
Dec 23, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Lighting Problem/2 year-Old Ducane Grill
Do you have enough gas pressure coming out of the regulator and gas valve? You'll need a pressure guage for this.
If yes, try taking out the burners and cleaning them with a wire brush, especially the flame spreading sections.
Sep 15, 2008 | Ducane 30400040 Stainless Steel Grill
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
