Question about Kenmore Dehumidifiers
Model 25836 warranty - Kenmore Dehumidifiers
No water in container
I have this model, and mine failed after 2 years. Fortunately it has a 5 year warranty on it. If you haven't cleaned the filter in the front, do that first. Take the bucket out, and then you can pull the filter down. In my case, I was getting an ice block on the front coils, and the warranty place determined it was a bad compressor. LG sent a refurbished model as a replacement for my broken one, and then I had to ship the bad one back in the box they provided. They also provided a return shipping label.
Jun 26, 2010 | LG LHD45EL Dehumidifier
I have the same model LG Dehumidiier with the exact same issue.
Your unit is still under one year old, and is thus still under factory warranty. This is exactly why you have a factory warranty. Use it. If you are in the USA, you can find a service provider at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
Bring a copy of your sales receipt to the service center to establish proof of date of purchase.
Jul 11, 2009 | LG LHD45EL Dehumidifier
Maytag Dehumidifier Model M7DH45B2ARevA Runs but doesn't collect water.
call 1-866-629-8241. they are no longer honoring the warranty because the maker of the dehumidifier, fedders, went bankrupt. if you have time on your warranty, they will send you a prorated check. we had two months left on ours and we got a check for $14 and change.
Jul 10, 2009 | Maytag M3DH30B2A Dehumidifier
Maytag dehumidifier model m7dh45b2a about 2 years old (5 year warranty) runs but does not remove any water
call 1-866-629-8241. they are no longer honoring the warranty because the company that made the dehumidifier (fedders) went bankrupt. they will prorate the warranty and send you a check. we had two months to go on ours and they sent us a check for $14 and change.
Oct 23, 2008 | Maytag M7DH45B2A Dehumidifier
Fan runs, no water collected
It appears that these units have a history of defectiveness. I bought one in late 2010 and it pooped early 2012. If the model is still made, buy a new one, return the defective one in the new unit's packing materials for a refund. Or keep the second (new) unit as a back-up, because the new (first) one may just fail again a short while later.
Oct 05, 2008 | Soleus CFM-40 Dehumidifier
Lg lhd65el dehumidifier icing up
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Jul 28, 2008 | LG LD65EL Dehumidifier
Gold stare dehumidifer
It sounds like there is an issue with the controller board. LG has a 5 year warranty on these models. You may want to contact them first instead of opening it up because it could void the warranty. My recommendation is to have this serviced if it is under warranty. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
Jul 20, 2008 | LG Goldstar LD65EL Dehumidifier
Reliable Dehumidifier Manufacturers
For an average basement I like the LHD45EL. It is quiet and also has an Energy Star rating which will make it easier on your electric bill. One other nice thing is LG backs this model with a 5 year warranty. A local store that I have seen carry this model is Home Depot and it usually runs aroun $179.
Here is a link with information on this model:
http://us.lge.com/products/model/detail/home%20appliances_air%20conditioners_dehumidifiers_LHD45EL.jhtml
If you found this solution helpful please rate it when you get a chance. Thanks - Tech101
Jul 03, 2008 | Dehumidifiers
No power
It sounds like there is an issue with the board. You will need to contact LG. This model has a 5 year warranty. If it is still under warranty it will be covered by LG. Here is the contact number for LG:
1 (800) 793-8896
Make sure that you have your reciept to show it is still under warranty.
Mar 14, 2008 | LG LD65EL Dehumidifier
DOES NOT TURN ON
Jan 13, 2008 | LG Goldstar LD65EL Dehumidifier
Dehumidifiers Logo
53 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
