Question about Boating
Over heating 2006 mercury 25 elpt efi 4s outboard
Water coming out hot from water pump outlet
bunnydawg
  • 5158 Answers
SOURCE: mercury 50 hp outboard
I actually thought it was down by the prop... i was wrong....
Pretty good diagram here.... look at part number 1
http://www.sterndrive.info/mercury-outboard-parts/60hp_to_125hp_component_layout.html
scroll down for the part cost and description.
Robert
Please take a moment to rate this solution.. thanks
Posted on Jan 23, 2009
  • 10 Answers
SOURCE: Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Posted on Mar 26, 2009
SOURCE: 1996 Mercury 150 Nitro EFI
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Posted on Jun 23, 2009
  • 154 Answers
SOURCE: Yamaha 50hp outboard
its working fine
Posted on Aug 03, 2009
  • 58 Answers
SOURCE: MERCURY OUTBOARD HAS BEEN SITTING (BY SALT WATER)
hi either that or remove the power head so it is easier to work on you will have to replace the water pump impellor anyway
i have done the following with seized motors and" most" of the time it works
use heat on all the bolts before you try and undo them heat the head of the bolt up then allow to cool then use a socket or ring spanner the heat will travel down the bolt ,transfer into the ally casting expand it and you will get the bolt out without shearing it
pistons /this sounds harsh but the motor is goosed at the moment anyway make shure power head is very sequre /socket or ring on flywheel nut 4/5 ft piece pipe over socket bar heat up engine oil OUTSIDE to almost boiling pour down plug holes until full leave 10 min pour oil out reheat it pour it in again 5 min try the pipe/socket clockwise GENTLY you are using a lot of leverage here just move it back and to a bit /then a bit more /then a bit more until it is free now strip it clean the bores up renew what you have to /put it back together
if that didn't work /i presume all the ancillerey's are off the motor /carbs ,elecrics etc plugs out /put p/head in a bucket full of diesel oil( cheaper than penertrating oil and better) leave it 7 days get ALLthe oil out send wife/partner /g/friend out for the day put the oven on max heat 300 degput motor in oven 2 hours max quick as you can /leather gloves or what ever hot oil in cylinders get a socket on the crank shaft and try it
last try you can only do this if a piston is on or near tdc modify a spark plug to take a grease nipple /cut the thread off /long reach plug and braze a grease nipple in it /put as much grease in the bore as you can screw the modified plug in and use a grease gun to force grease in as the grease will not compress it WILLpush the piston down untill it uncoveres a port /messy but at least it has moved it once you have got some movement eventualy the motor will free off best of luck merlin v12
Posted on Aug 29, 2009
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
I have a 1995 Mercury 150 hp EFI outboard. Coming in on last fishing trip the alarm and flashing light came on for high heat/low oil.
sounds like perhaps the oil injection pump failed . last one of these we just added oil to the gas and continued using it .
Aug 22, 2015 | Mercury Cars & Trucks
I have a 1980 mercury outboard. It has a new water pump but still can't get water out of Tell Tale hole and I have poked wire down it. Where do we go from here.
Good Morning William Remove The Hose From The Block,See If You Get Water From There. It Could Be A Blocked Hose .
If Water Does Not Come Directly From Engine Outlet Then You May Still Have A Problem With The Water Pump.
When You Re Fitted The Leg Did You Ensure The Copper Pipe Engaged With The Water Pump Housing?
Regards Gordy
Jun 14, 2015 | Boating
Mercury outboard problems
Is this a two stroke?-If it is you most likely have a primary seal going bad (crankcase seal on the ignition side will lean it out,leaking seal on the other-side of assembly will do just what your describing)Hope this helps you out.....
Aug 07, 2014 | Mercury 4-Stroke 3.5 HP Outboard, Manual,...
Mercury outboard
are you sure the water pump is workiing
Jul 01, 2014 | Boating
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Boating Logo
80 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
