Question about Gilmour Bp4 4.5 Gallon Back Pack Sprayer
4.5 gallon sprayer doesn't work - Gilmour Bp4 4.5 Gallon Back Pack Sprayer
I have a 1999 Nissan quest. The front and rear windshield wiper don't work. I can't even hear the motor going just nothing and front and back wiper fluid doesn't turn on either. We checked the...
test the flasher relais and clean it the contacts. test the connector and wires for loose, or corroded. Test the fuse too see the diagram attached.
Jul 08, 2013 | Cars & Trucks
Rear windshield wiper sprayer doesn't work but the fronts work fine 2002 jeep liberty limited
The rear wiper has its own pump motor. pull the hose from the wiper and have someone engage to see if there is a clog. do the same at the motor. if bo liquid comes out then its the pump. also check fluid level in reservoir as well as a possible secondary reservoir
Dec 01, 2012 | 2002 Jeep Liberty
Need an o ring
Check with the guys that fit tyres..They normally have a variety of these O-Rings.. Not sure what they use it for but it worked for m
May 18, 2012 | Cepia 1 - Touch 1/2 Gallon Rose & Garden...
I've just been given a roundup 2 gallon sprayer. It seems to me the top should be removable to add the liquids but I can't figure it out and don't want to experiment to the point that I damage...
Howdy MMis971,The sprayer just needs to be pushed down by the handle as you turn counter clockwise. This can be made a little easier by unscrewing the nozzle where it connects to the tank to release any pressure built up by pumping.
Happy Gardening,Coach Dave
Sep 10, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Need a part for the sprayer. wasn't in the box the pipe with the sprayer end on it
Howdy g5483,Most reputable retailers' will either let you exchange the sprayer or get you the part. At The Home Depot we will gladly do either one to get you what you need.
Coach Dave
Aug 29, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
Need to buy parts for gilmour backpack bp4. Where can I get them?
Got the same sprayer, can't get parts. Toss it in the trash like I did, don't buy anymore Gilmour products.
Aug 01, 2011 | Gilmour Bp4 4.5 Gallon Back Pack Sprayer
I'm not sure how to fill the thing. It's a 2 gallon sprayer, yet when I open the top (i.e. remove the pump mechanism), there is a chamber, but it only holds about 1/4 gallon. How do I get the...
it sounds like you unscrewed the pump assembly. that chamber is actually part of the pump and sometimes they do separate. try to remove what you called the chamber. if that is part of the pump then it has to come out before you can put the pump assembly back together.
May 25, 2011 | H.D. Hudson 2g Yard N Garden Sprayer
Gilmour Bp4 4.5 Gallon Back Pack Sprayer Logo
55 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
