Question about Gigabyte GA-K8NS Motherboard
What other cpus will work in the GA-K8NS PRO nforce3 250
Its says in the manual socket 754 will all amd cpus work with that socket??? can you send me a list of cpus that will work with this mother board thank you i am looking on ebay to find some its only a singel core but i have a amd athlon 64 2800+ thats only a 1.8ghz and it sucks i need to put a better one in here witch ones will work????
    President:
  • 2,692 Answers
Hee is the link to your CPU support list. for model GA-K8NS Rev2
Looks like that 3700+ Newcastle with 1GB on the chip  is the best on the list.
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=2275#anchor_os
Posted on Mar 12, 2009
AMD SSE2 patch
Only the socket 754 and higher Sempron CPUs support SSE2, and some of the early motherboards require a BIOS update.
Jun 12, 2014 | AMD Sempron 2800+ CPU with Mother Board...
What does code 7f mean on kv8 pro
Did you ever resolve?
This is the board with the external OC monitoring panel, right?! I owned this, too. I had a similar KV8 board from Soltek, as well--post codes, also. My Abit died several years ago.
The ABit's manual still exists online. According to the code, It's hanging on the onscreen logo--it says to switch to text. Here's the page describing your code: http://www.manualslib.com/manual/615/Abit-Amd-Athlon-Kv8-Pro.html?page=69#manual
If I remember correctly, that's not a serious error code--popped up often after new installs.
If it's a hard drive error--do you have the master/slave configuration jumpers correct? (Hard drive vs. Optical drive? Probably, you want the hard drive as master--optical as slave)
Is cable orientation (Pin 1--from PATA cable and at drive(s)/board) correct? Perhaps I remember now--maybe the BIOS can't get to the hard drive and OS.
Is your floppy light always illuminated (it shouldn't be)--is that cable installed correctly?
If your onboard hdd controller is dead--and, you worked with AGP over the years--you likely have a PCI card that will take its place. (If not, you may purchase that pretty easily. still.) Syba, Siig, Sabrent, StarTech, etc.
If your controller is OK, have you tried running a live i386 (32-bit) or AMD 64(64-bit) Linux disk or an old Bios upgrade/DOS floppy--to see if you get some type of OS posts? Is your proc 64-bit or 32-bit?: If I remember correctly, 754 CPUs generally were 64-bit--some were 32-bit, though (I still own one of those, too).
Did you clear your CMOS first (move the jumper for a few seconds and back)? Is the jumper correctly installed now?
Ah, the days of socket 754 (I never obtained Socket 939.....) Socket 754 still is a good value--you may obtain such a proc for about $5 on Ebay. (Used boards are a little pricey--considering.) I get the sense that 754 was the business board--939 was the gamer board.
Recently, I resurrected my old Shuttle Athlon XP board--considering its age, it holds up pretty well. Works fine with 32-bit Linux Debian distros. Dual-channel. Great OC board in its day. Currently, I have a 9800XL card in--soon, I'll put in a 3850 AGP....
May 23, 2014 | Abit KV8 Pro Motherboard
Will a dual core or multi core processor fit into and work in a elitegroup 761gx-m754 motherboard?
Unfortunately there are no dual core CPUs for this motherboard. The 761GX-M754 motherboard has a 754 socket which supports the Athlon 64 / Sempron CPU. AMD never released a dual core CPU for the socket.
I wish that I had better news for you.
Sep 17, 2011 | EliteGroup 761GX-M754 Motherboard
Nead to replace my motherboard ga-k8vm800m
http://www.newegg.com/product/product.aspx?item=N82E16813128262
So you need a motherboard that has a Socket 754 processor socket, supports AMD socket 754 processors with up to an 800MHz FSB, uses DDR Sdram 400MHz ram memory, (PC3200), and has an AGP graphics slot.
From a quick search just now I see a lot of them listed on Ebay.
NOT advertising for Ebay.
I saw other listings on the internet also. (GA-K8N51GMF-RH - Way too pricey!)
Regards,
joecoolvette
Aug 07, 2011 | Gigabyte GA-K8VM800M Motherboard
Can you tell me why when i put CPU in my computer he give error? CPU is AMD Athlon 64 3400+ 2.4GHz socket 754.My motherboard is socket 754 Gigabyte GA-K8NE-RH. Problem is my computer or CPU?I take CPU...
The motherboard will support this CPU, with the F1 bios.
I can only advise, that IF your motherboard was working ok before you put the new CPU in, it must be the new cpu you bought.
If this is the 1st CPU you have tried, there is a chance the board is damaged
Jun 13, 2011 | AMD Athlon 64 3400+, 2.4 GHz...
Can I use DDR2 800 MHz RAM on GA-K8NS-Ultra-939-Socket-939 MBoard
I don't think that that motherboard will accomodate the DDR800 you probably need a DDR333 or DDR400.
Calling the manufacturer support will render better information because they made the board. The memory you refer to may not fit the slot for this particular motherboard.
Aug 13, 2009 | Computers & Internet
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Gigabyte GA-K8NS Motherboard Logo
138 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
