Question about Asko 24 in. 1585 Built-in Dishwasher
Replace heating element
Want to know how to remove old element to replace with new element
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
No heat at all.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 26, 2009 | Roper REX3614KW Electric Dryer
Electric dryer not heating...works fine, but no heat
Jun 04, 2009 | Roper RGS7646KQ Gas Dryer
No heat
Apr 21, 2009 | Kenmore 62802 Electric Dryer
Need to Replace Heat ELements
you remove the screws that hold on the base plate that has the sequencers mounted on it. pulling it out so the elements clear the sides of the unit. once you remove it you can easily see the heating element coils which you can purchase a restring kit fairly cheap at your local appliance parts store. just remember to stretch it out uniformally the same length as the old one, reinstall the heat kit the same way you removed it. kit comes with new ceramic gromets if some are damaged. these units do have a 5 yr warranty on the heat strips.
Jan 12, 2009 | Ruud UBHC Air Conditioner
After 2.5 years and approc 10 uses the bottom element in the oven went out. Is this an expensive item to replace or can a novice person order the part and replace it.
easy get the model number off the stove,look on top panel back or inside the oven door,call your local appliance part store with model number,remove the back panel and you will see 2 leads for the bottom heating element remove leads,inside oven are 2 screws holding element on remove pull out old element replace with new one,let me know how you did,thanks-mike
Jul 15, 2008 | GE Kitchen Ranges
Dishwashers Logo
20 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
