Question about HP LaserJet 1020 Printer
Black lines on the right side
I note that others have identified the same problem, but I've done a bit more troubleshooting ... Basically, thick black dotted lines print on the right hand side of pages which contain any graphics eg. .jpg files. Normal text in Word, numbers in Excel or even music prints fine. I'm having the same experience printing website material that is rendered for printers - anything with graphics prints the black line down the page, while other pages are fine - in the SAME document. I've called HP and they've never heard of it. I will send them copies, but I wondered if anyone else had had this issue.
  • 4 more comments
  • sachingoel Mar 20, 2008
    problem of vertical black line on the right side of print output in hp laser 1018 when images are print
  • Anonymous Mar 28, 2008
    ditto- line down right side of paper when I print.
  • Jeff Barber Apr 22, 2008
    We are having a black vertical line print about 2" from the right margin
  • Anonymous Nov 18, 2008
    exactly the same
  • Anonymous Dec 19, 2008
    I have HP Laser Jet 1020 and I have the same problem. Pages without any pictures or images prints fine. Ones I insert images, it prints thick black line on the right side of the page.
  • Anonymous Mar 21, 2014
    yellow line down side of pages
The vertical black line at the right-hand side of the page when the printed document includes an image is a problem with all currently available HP Laserjet 1018, 1020 and 1022 drivers. While waiting for HP to fix the problem (they haven't even acknowledged it yet in their webpage) you can bypass it thus: a) Click on the 'Properties' button. b) Click on 'Finishing' and select 'FastRes1200' (this makes the line narrower). c) Click on 'Basics' and select 'Rotated', i.e. printing the page from bottom to top (this elliminates the line completely, in combination with 'b' above). This is a home-made solution I found after numerous trial-and-error attempts and having downloaded several drivers from the web. As a token respect to all of us who have paid money to buy these printers, I hope HP will soon recognize and solve the problem.
Posted on Sep 25, 2007
I had the same problem. Confirmed that it is graphics related - by removing graphics and getting good printout. Then reinserting them and the black lines came back. Fixed it by changing the printer resolution.Once you say print - click on the "properties" button and then go the "Finishing Tab" on the bottom right change "Print Quality" from 600dpi to FastRes1200 in the pull down menu. This made my black lines go away.
Posted on Sep 07, 2007
Thanks for the solution
1.check rotated option
2.change the res to 1200dpi
it did really work! thanks a lot
Posted on Dec 13, 2007
  • Anonymous Dec 13, 2007
    thanks for the solution
    1. check rotated option
    2. change the res to 1200dpi
    New Friend:
Black lines on the right side - 8_4_2012_6_05_26_pm.jpgHP laserjet 1020 produce a black line down the right hand side of page
Posted on Aug 04, 2012
Install new plug & play driver for HP Laser Jet 1020 printer from HP web site. It will get rid of the black line on the right side of the pages.
It fixed my problem.
This is the web site;
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=439428&lang=en&cc=uk&prodTypeId=18972&prodSeriesId=439423&taskId=
Posted on Dec 19, 2008
The resolution-and-rotated workaround was ok for me
thanks.
but once again, it has to be a better way
Posted on May 10, 2008
Want to confirm that I am having the same problem with HP1018, latest drivers from HP. Win Vista.
Fastres1200 seems to fix it, but I would prefer to do most of my printing in 600
Regards
Oli
Posted on Apr 30, 2008
Friends
i have same problem of balck line on right side ,it is international problem in Hp drivers, i downloaded a single driver file from hp website now my problem solve.
so the only solution is download latest driver of ur printer from HP website with a file comes to solve this problem
on Hp website there is a small file , download this file which solves ur problem
u dont need to go anywhere, only download file from hp website
Posted on Apr 23, 2008
I changed resolution and flipped. It works, but there has to be a better way.
Vangelis's solution works but like he says it's a backward fix.
Posted on Apr 16, 2008
Thanks for the solution, it works
Posted on Mar 05, 2008
Just to confirm to everyone: If you go to control panel, select the printer and click properties-printing preferences-finishing and select FastRes1200 it solves the issue completely - i've tried it!
Posted on Oct 22, 2007
Hi, I have the same problem... but with HP LJ 1018. HP must do something...
Posted on Oct 05, 2007
  • Anonymous Oct 05, 2007
    I have the same problem with HP LJ 1018.
    HP must do something!
I am having the exact same black line problem on the right hand side. We just deployed a brand new PC for a user with one of these printers and following our standard procedure we downloaded the lastest and greatest drivers from HP's web site. Now she has the black line issue (I don't think it is a hardware issue since it worked perfectly before on her old machine). This has got to be a driver issue... I am going to look for the original CD as suggested. -Eric
Posted on Aug 24, 2007
Same problem here and we have two 1020's in our office. Luckily they are just a supplement to our workgroup printers but it's pretty annoying and even more so to find out HP won't support this issue. We print the same Excel sheets on three different printers and neither exhibit this problem. Only the 1020's consistently have this problem, even when attached to different machines with differing OS's (Win2k, XP, Vista). So if you are planning on doing allot of printing from Excel you might want to consider another printer.
Posted on Aug 10, 2007
I'm almost positive it's an issue with the drivers. I was reinstalling XP today had the exact same problem. The HP 1020 was working perfectly before the XP reinstall, then I got the the lines down the side when there was a graphic in Firefox. When reinstalling the printer, I tried to just get the drivers instead of getting the bloat that comes with the normal installation (order reminder, etc.). I thought this caused the problem, so I deleted the printer and installed of the CD. This didn't solve the problem. Since I was just about an hour into my reinstallation, I just started over again from scratch. When I got to the printer, I installed off the CD (following the directions) and it works fine. So that's why I think it's something with the drivers. When I did it improperly, it didn't work. When I tried to fix it by doing it properly, it didn't work. It only worked when I removed everything relating to the drivers and reinstalled. I'm not saying you should nuke your system (although in my case it worked), but if you can get someone from HP to give you the names of all the files normally put on the system during install, delete those, then do a clean install, it may work.
I have had this same issue, and the people at HP keep telling me it's an application problem. I've never had the issue before I installed the HP LJ 1020. Down the side of any page with any graphics, you get what look like line markers. I have tried reinstalling the drivers multiple times, and reinstalling MS Office 2003, and still the same issue. This issue does not exist with an HP OJ 6110, which I had before. I even had the LJ 1020 replaced, to see if it was just that printer that was defective, but the new printer still had the same issue. My solution is to buy something other than HP LaserJet 1020. And the tech staff at HP were completely UNHELPFUL. They just kept insisting it was not the printer, and it so obviously WAS.
Posted on Aug 08, 2007
  • 186 Answers
Have you tried changing the toner cartridge? I know it sounds too simple, but that is a good place to start diagnosing.If you could email me a sample I could maybe help more. The other possibility is the fuser assembly may be bad. If thats the case, most times it is not feasible to repair. But it is hard to say with out seeing a sample.
Posted on Aug 03, 2007
I've just purchased an HP 1020 and installed it on a system running Windows Vista. The CD that came with the printer doesn't include drivers for Vista, so I downloaded and installed the latest Vista drivers from the HP web site. I ran into the very same problem described by other posters. HP tech support was no help at all. They said it had to be an application problem, even though I pointed out that the same thing happens when printing from five completely different applications, and I have no problem printing the same images on two other printers here. I asked to speak to someone knowledgeable about printer drivers, but they would not give out any contact information. I guess since the printer is brand new and HP refuses to deal with the problem, I have no choice but to return it to the dealer and look for another make and model.
Posted on Aug 14, 2007
SOURCE:
My HL2040 printer is printing black vertical lines along the right-hand side of the page, about 3" or so. A month ago I took it apart and cleaned the roller. Still doing it.
If the lines go all the way down the page, check the position of the corona wire cleaner tab (blue or green) at the top front of the drum unit. if not parked fully to one side it will create a solid black lines where it blocks the laser. Otherwise look for some other foreign object (or torn paper piece) that may be blocking the laser from the drum. If the lines are thin and shark, check for scratches on the drum (not repairable without replacing drum). If the lines are uneven thickness but in a pattern that repeats down the page every few inches, then the film on the drum is probably worn or wearing away and the drum needs to be replaced.
Mar 04, 2015 | Brother HL-2040 Laser Printer
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
Black thick line going horizantal on screen can it be fixed?
Usually a bad board but someone has to open set and troubleshoot to decide which board is the problem.
Apr 08, 2012 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
How to sew in a zip? with Empisal dress maker 270
Sewing in a zipper is a fairly easy process, though a bit hard to explain in words :) You need an iron, pins and a zipper foot for your machine. The zipper foot allows the needle to get close enough to the teeth of the zipper without the foot getting hung up by the teeth.
The best thing to do in order to understand the process if you've never done one before is to look a a video on youtube and watch how a zipper is put in. Here is one link that shows how to insert a zipper http://www.youtube.com/watch?v=ue5z2rWS588&feature=related ...but there are several others too. Some show specifically "invisible zippers", some show side seam zippers and others show how to put one in where you have a waste band. When you get to the link above look to the right side of the page where you will see other videos to pick from too.
There are lots of interesting sewing videos on youtube. You'll note that though the process is basically the same different seamstresses have different tricks for getting a straight and tidy looking zipper.
May 16, 2011 | Sewing Machines
Kyocera Mita Ecosys PS 1010 all prints have thick and thin line down left hand side A little while back the printer started printing completely black sheets. Fixed by turning off and then on again. Since...
Try cleaning the charge wire. Move the lime green plastic handle from one side of the image unit to the other in the groove. If this doesn't work you'll need a new image unit.$$$$$. note: Make sure green handle is moved completely to the right when finished or black line will occur.
Feb 09, 2010 | Office Equipment & Supplies
LARGE HORIZONTAL BLACK LINE- PSC 1610 PRINTER COPIES
NO, I DID NOT GET IT FIXED. YOU TOLD ME TO SCAN SOMETHING TO THE PC, WHICH I DID. SENT PAGE TO MICROSOFT WORD AND THE BLACK LINE WAS STILL THERE. I BELIEVE MY SOLUTION IS TO JUNK THIS THING AND BUY ANOTHER.
Jan 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Black line down the right hand side of everything I scan
it is problem your copier scaner mirror is derty
clean it
Jul 22, 2009 | Brother MFC-9440CN Laser Printer
VERTICAL LINE ON TH-42PX70B
there is nothing you can do.the display  panel is defective and you must replace it
Oct 28, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Black lines down page
It must be the black pcu , the cleaning blade picks up dirt and causes these lines , it can also be the black developer giving you trouble , if you want be very carefull aand strip the pcu open you will see the lines only on the inside and not from outside , then you will know if it is developer or the cleaning blade
Oct 24, 2007 | Ricoh CL4000DN Laser Printer
HP LaserJet 1020 Printer Logo
1,826 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
