Question about Sangean HDR-1 Radio
It won't turn on anymore. My HDR-1 worked a few days, and then refused to come on. Neither the remote nor the power knob can bring it to life. I replaced the battery in the remote control, but it didn't help. Now what?
  • Anonymous Apr 01, 2009
    its the same as mine . main tranfromer has gone in side its a odd one as well am still lookin around it got three low volts on tranfromer not like your average 240 volts in 12 volts out be deer as well!
Ive got same fault main tranformer in set a odd one
Posted on Apr 01, 2009
I have a toshiba tv 39al900a which was won in a raffle. When you turn it on it says please scan channels.t.
The first step is to make sure you have good batteries in the remote. The ones included tends to be cheap and you have no idea how old they are.
Here is the manual, page 12 explains how to use the remote and the next few pages cover the initial setup and scanning of channels.
http://www.mytoshiba.com.au/file/download/resource/file/23089/39al900a%20owner's%20manual.pdf
If the remote is still not working, get a universal remote to replace it. This link gets you the codes to program the universal to work with your TV. http://codesforuniversalremotes.com/universal-remote-control-codes-toshiba-tvs/
Feb 05, 2017 | Toshiba Televison & Video
Humax HDR-7500T will not power on
power adapter first control is should not give a stable dc anymore by bad capacitors. is the most most common defect by this The capacitors are enabled by continuity of day and night and thus they lose their self-healing capabilities because they are too tight tolerance
May 29, 2016 | Televison & Video
Knob on amana window air conditioner cracked and won't turn on
The knob has a metal post clutch sleeve on its stem. Place a flat bladed screw driver on a small piece of flat wood a 1/4 of an inch high. Lightly pry upwards it will slowly move up and off the shaft. Now if its just cracked, get a poly solvent glue kit wrap the out side of the knob with a couple of turns of the tape cut and adhere the wrapped knob with the tape. Turn on the solvent glue tool and coat the inside of the bottom of the knob being careful not to obscure the shaft inner sleeve. Partially fill the knob, turn on the UV light and cure the cement until hardened. Repeat this step until the knob is as hard as it can get. Any over flow just carefully trim and sand. Get some model paint enamel just give it a few coats and let adequately dry between coats
Nov 09, 2017 | Heating & Cooling
My Sony HDR-FX1E refuse to power on
These camera are not DIY repair candidates. I would suggest that you seek out an authorized Sony service center. Most of these are sent to 1 of 2 locations for repair for a fixed cost.
Dan
Aug 24, 2010 | Sony Handycam HDR-FX1E Camcorder
Humax Foxsat HDR sudden Remote Control failure..
Make sure you have pressed the "PVR" button at the top. If you have accidentally pressed on on the others TV, DVD or AUDIO then they will light up when you press another button signifying that the remote is trying to send a signal to them rather than the PVR...which is where you want it to go.
Nov 10, 2009 | Televison & Video
NES won't turn on.
Well I think that it has died now so the power deck needs to be replaced I have replaced the power deck for NES before AND ITS EASY TO FIX TAKES ME LESS THAN 60 MINUTES TO REPLACE.
Jul 30, 2009 | Nintendo NES Console
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
Sangean HDR-1 Radio Logo
173 people viewed this question
Top Sangean Audio Players & Recorders Experts
Gyula Lacz
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
