Question about Lexmark Polaroid P310 Photo Printer
What ink cartridges do i use for a polaroid p310 photo printer
SOURCE: helpppppppppp
Jan. 12/08
I have same printer. No manual. Guess it's too simple and the creators don't think general public need instructions! I am using a Canon S1 camera. My camera screen said to press the "SET" button to print the picture that I had on my camera screen. It worked for me!!! Good luck. I'm guessing printer only prints from a camera, hence it's portability.
Posted on Jan 14, 2008
SOURCE: instructions manual for Lexmark Polaroid p310 photo printer
http://www.lexmark.com/publications/pdfs/310/eng/ug.pdf
This link will take you to a manual for the Lexmark 310/315 series. It doesn't show the P310 Photo Printer exactly but the information can be helpful. On Page 15 is tells you how to get the printer to print exactly the picture you want. You need to refer to the instructions that came with your camera for PictBridge connection and usage. It helped me.
Posted on Sep 08, 2008
vegakitten20
  • 685 Answers
SOURCE: Lexmark x2650 printer not responding to new cartridge
yes you have to have both of them then everything should be fine.if you have the color cartridge that is empty put it in for now and see if it will work it will let u know that it is empty but at least you will be able to print in black
Posted on Jan 04, 2009
  • 684 Answers
SOURCE: lexmark 5400 Printer does not use the photo cartridge
First of all as this Catridges are Non Intelligent they will not be able to show u the exact Ink level on the catridge then too if thats really happening this Solution below will fix it: In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the Photo on the left........ Good Luck
Posted on Jan 28, 2009
voodoomox
  • 1689 Answers
SOURCE: Instruction manual for Lexmark Polaroid p310 photo
here ya go buddy
http://www.lexmark.com/publications/eng/310/index.html
Posted on Aug 09, 2009
Theres nothing in my printer to put the ink into
It could be that the cartridge carrier just did not move to the loading position. If you're having trouble with the cartridge carrier not moving automatically to its loading position (to install/replace cartridges) even when the printer is on and the cover is open, please follow the steps below:
  1. Unplug the printer from the power source.
  2. With the printer cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the carrier to the center of the printer.
  3. Open the latch and remove the used cartridges.
  4. Load the new cartridges. Close the latch and then the printer cover.
  5. Re-plug the printer to the power source.
  6. After going through the startup process, try to print a document to verify that the cartridges are working and installed properly.
Jan 07, 2012 | Lexmark Polaroid P310 Photo Printer
Dont know what number ink cartridges I need
For the Lexmark Polaroid P310 Photo Printer you will need cartridge number 33 and 35.
These are both available on the Lexmark website for ordering and purchasing online or you may want to visit a nearby store for the same.
This will resolve the issue you are facing.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will look forward to your feedback and positive rating.
Sep 09, 2010 | Lexmark Polaroid P310 Photo Printer
Polaroid P310 Photo Printer: i need drivers for...
http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
May 18, 2010 | Lexmark Polaroid P310 Photo Printer
I have the same issue - did you ever get it resolved?
Two possible causes...corrupt software or empty ink cartridge. there is usually an area on the printer menu for maintenance where you can check the status of the ink supply. replace any empty cartridges. Clean the print heads (wipe with alcohol rag) if they are not part of the replaced ink cartridges. If you're still having the problem...reinstall the printer software.
Sep 15, 2009 | Lexmark Polaroid P310 Photo Printer
Instruction manual for Lexmark Polaroid p310 photo printer
here ya go buddy
Aug 09, 2009 | Lexmark Polaroid P310 Photo Printer
Printing by Lexmark P310
Have you installed the printer software?
Aug 26, 2008 | Lexmark Polaroid P310 Photo Printer
Helpppppppppp
Jan. 12/08
Nov 09, 2007 | Lexmark Polaroid P310 Photo Printer
Instructions manual for Lexmark Polaroid p310 photo printer
Oct 21, 2007 | Lexmark Polaroid P310 Photo Printer
Lexmark Polaroid P310 Photo Printer Logo
238 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
