Question about Singer 3116 Simple
Hand Wheel Won't Turn
I have just bought a new Singer 3116. Starting sewing for a while and then when I put my foot on the foot pedal the needle would not come down and the handwheel would no longer turn backwards or forwards. What am I doing wrong or is this a problem machine? Nothing is jammed. I have tested upper thread test and bobbin test. Both seem to be fine.
  • kalcan8 Mar 29, 2009
    I have an old Singer and I have the same problem. I've oiled it and looked for a loose thread in the bobbin area under the face plate and didn't find anything. I hope someone can help.
The "Bobbin stopper" is in the incorrect position. It moves from side to side in a switch like motion. In one direction, it locks up the machine. That is, you can turn the wheele backwards, but not forward.. The bobbin stopper can be found in the book that cam with the machine. In our book, it is item #9.
Posted on May 01, 2009
    New Friend:
CHECK THE BOBBIN SWITCH.
Posted on Nov 17, 2013
I recently took mine in to get fixed. The problem was that there are 2 holes where the spools sit ontop of the sweing machine and the pin was in the wrong hole. Everytime I would start sewing the vibrations from the machine would make the pin drop down and stop something from moving inside. Took 1min to fix and cost $5. Now is working great.
Posted on May 04, 2009
    Sergeant:
    Habit-Forming:
  • Singer Expert
  • 106 Answers
I don't really know much about sewing machines, but I found a user's manual, so maybe it will be useful to you. Best of luck Singer Simple 3116 manual
Posted on Dec 20, 2015
Belt not gripping on singer 237 and needle doesn't go up and down
1. The motor has a bolt that you have to loosen and move up and down for adjustment.
2. Take the needle out first before adjusting.
3. You will slowly apply pressure to the foot control pedal until the motor is moving. Pull up on the motor to a point where the motor moves the fastest.
4. Tighten motor. Check again afterwards.
5. It is essential that the center of the hand wheel is tightened before you begin.
Nov 02, 2016 | Singer Sewing Machines
Foot pedal does not operate needle
[PDF]INSTRUCTION MANUAL - Singer
www.singerco.com/uploads/download/445_4830_4832.pdf
around the sewing machine needle. ... ings of the machine and foot controller ... The spool does not turn. 7. ... Note: Do not operate machine without fabric.
Oct 29, 2015 | Singer 3116 Simple
Where can I find a power cord for singer simple 3116 sewing machine?
It looks like your power cord and foot pedal are incorporated into one unit, and you'll have to replace the foot pedal to get it. You can get it for $30 at sewing parts online, http://www.sewingpartsonline.com/singer-3116-simple-sewing-machine-parts.aspx?gclid=CLTXmrLC18ECFeHm7AodBioADg, and you can also get them from eBay by doing a search on Singer Simple 3116.
Oct 16, 2014 | Singer 3116 Simple
I can turn the hand wheel backwards and the needle goes all the way down but if I turn it forward it only goes half way down,why?
It could be a matter of timing. Try taking the needle out and then turn the wheel forward. Using the foot pedal without the needle will give you an idea as to how much off the timing is. It might just need to go to a machine mechanic.
Sep 05, 2014 | Singer 3116 Simple
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
How do i thread this? need visual guide please. i can hear something moving, but pedal isn't going up/down.
The "pedal" is the foot pedal and it powers the machine and does not go up and down.
The needle and needle bar go up and down.
If there is a smaller wheel in the center of the handwheel (wheel on the right side of the sewing machine), make sure it is tight. Turn to the right (toward the back of the machine).
You can find threading, bobbin winding instructions and a manual at the Singer Company website.
Mar 12, 2010 | Singer 3116 Simple
I have a Singe 3116. The needle not working
the clutch is out. that allows you to wind a bobbin. take it out of bobbin mode and put it in sew mode (clutch in)
Feb 26, 2010 | Singer 3116 Simple
Singer 600 touch and sew
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Oct 23, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
1,731 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
