Question about Electrolux EW26SS65G Side by Side Refrigerator
Is main control board on bottom of refrigerator rather than back
CE error
2 Suggested Answers
SOURCE: Same prblem as person who listed Alarm going off
I ended up buying the parts from Electrolux - cost $384 plus tax. The repair is relatively easy and you can do it yourself. My problem was locating the main power board - who would have thought it would be behind the front kick plate attached to the bottom of the refrigerator.
Posted on Oct 21, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Why am I receiving a CE error on my Electrolux refrigerator?
Thank you for your inquiry, friend!
"CE" stands for communication failure on your Electrolux refrigerator. You could be seeing an issue within your main control board or user interface board. I would suggest having a technician come out to properly repair your appliance. -Matt
Aug 30, 2014 | Electrolux Refrigerators
Fridge digital display is showing CE, WATER DISPENSER BOT RUNNING WATER AND MOTER IS NOT ON
Hi berniekeenan -
Error code CE typically indicates a communication issue between the user interface and main control board. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the refrigerator back on. If the error code continues, I recommend scheduling service so a technician can accurately diagnose and repair your refrigerator.
Apr 20, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Sy ce on fridge door
Hello Debbie Lee - Typically error code SY CE indicates that the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need placing.
Feb 02, 2013 | Electrolux EW28BS71IS (278 cu ft) Bottom...
5y CE code on frigidaire refrigerator water/ice dispenser
Dear Sue,
  • SY CE Error Codes is a very common issue : the display board isn't communicating with the main PCB.
  • Unfortunately, there is no way to test which board is causing the problem. That's why this error can be costly.
  • Try to just unplug the refrigerator for 15 minutes and plug it back in to see if the error goes away.
  • If the issue doesn't go away, then you'll need to replace one or two boards.
  • Usually the Main Control Board under the refrigerator behind the kick panel is the part that tends to fail.
  • If you Change the Main Board, it does not work; you gonna have to replace the Display Board.
  • Try buying these board at an online store that accept Returns without conditions up to a year. Go online and put the boards number into any major search engine. Put the # one by one. You will find many sellers. Carefully pick one and do you homework
Good luck and keep me posted please,
JP
Jan 13, 2013 | Frigidaire Refrigerators
CE error code on electrolux refrigerator
Hello Alan Rapp - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
Jan 02, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Error code CE
"CE" error mean you have a communication error at power up. Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board. Good luck
Sep 09, 2012 | Electrolux Refrigerators
Display panel shows CE
CE is a general communication error. If you do not see any other error codes on the unit Check wiring between Main Control Board and User Interface Board. Replace User Interface Board. If problem still exist, replace Main Control Board.
Sep 01, 2012 | Electrolux EW26SS65G Side by Side...
Same prblem as person who listed Alarm going off EI26SS55GSO how much does it cost to replace control board, dispenser unit, touch pad and main power board ? shows error code CE CE
Oct 21, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Electrolux EW26SS65G Side by Side Refrigerator Logo
24 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
