Question about Dewalt Heavy Duty VSR Drywall Screwdriver DW255
How to remove bit from dewalt dw255 - Dewalt Heavy Duty VSR Drywall Screwdriver DW255
DeWalt 20 V impact. Driver ejects occasionally. Locks in correctly to start then after limited use, bit holder falls out.
These are known for the spring in the nose (#12) to fail.
Using an o-ring pick or small screwdriver remove the hog ring on the end of the bit holder (#17).
Slide the washer, spring, and sleeve off (Be careful not to lose the small lock ball)
The spring that pushes the lock ball forward (#12) is usually the culprit.
Reassemble in reverse order DeWALT DCF886D2 20V Impact Driver Parts
Dec 06, 2016 | Dewalt Drills
Chuck keyless removal
drill it out with a drill bit so that you are removing the head of the screw. this will work i have done it many times.
Aug 13, 2013 | Dewalt DC930KA Heavy Duty Xrp 14.4V...
I have a DEWALT DC920 drill-driver and have a bit stuck in the chuck. The chuck adjuster appears to be stripped. Need to remove the bit and replace the chuck. Any ideas on how to get the bit released?
try tapping on all sides of the chuck lightly with a hammer and wiggling the bit... you can also try to spray some oil into the chuck and see if that loosens the bit for you... You can also clamp the bit in a vise (or get someone with a pair of pliers) and pull, that will sometimes do the trick.
Apr 04, 2011 | Dewalt 18 Volt Compact Drill Kit
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
Removing centre screw from chuck
Drill a hole in the top of the phillips head screw with a 3/16 th's bit. Don't drill the head of the screw off, just drill deep enough for a torx bit to hold. Take a T-30 torx bit and tap in into the hole you have drilled. Then turn the screw clockwise and it should come out fairly easily.
Mar 26, 2010 | Dewalt Drills
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How to Remove Bit from Dewalt Quick Connect Adapter DW0521
Hold the chuck by its sleeve, put the drill in reverse (make sure it's set at high torque if you used it in a drill/driver) and go full speed. That should release the bit.
Jan 04, 2009 | Dewalt DW0521 Quick Connect Impact Driver...
Dewalt Heavy Duty VSR Drywall Screwdriver DW255 Logo
710 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
