Question about Water Tech Pool Buster Max Cg
My pool buster max will not turn off even though the knob is in the off position. How do I get it to stop running?
2 Suggested Answers
SOURCE: The pool buster won't run at all.
I had the same problem when I started to use mine at the beginning of the pool season here. If yours is anything like mine when I opened it up I found the motor was completely rusted and the drive gears would not turn. I'm not sure if the batteries are dead as there was a lot of corrosion on the charging terminal. It is simple to open the case and then open up the motor/battery housing - just a LOT of screws!
The options seem to be buying a replacement battery and motor pack from Aquatech the makers and replacing the defective unit. I think the cost is around $130 but for that sort of money you can buy a new one on Ebay - depends if you have the Commercial Grade unit but I've seen that new on Ebay for $185ish too
If it is just the battery you might be able to buy a replacement battery alone from Aquatech but I haven't checked it yet - on thier site it shows only the whole motor and battery unit as a replacement. In theory it should be possible to get a set of batteries made up for a lot less than Aquatech probably charges - I saw one web posting where a guy had Interstate make him up the batteries for $28.
Frankly, the pool buster seems to have a lot if issues once it gets old (past the 1 year warranty) and the battery charger had a lot to do with the issues as it would overcharge. From my research it seems a common problem that water can enter the unit if the seals on the screw in starter fail. BTW the unit is now called the Pool Blaster but to all intents and purposes seems like the same model but with a different catch on the front holding the plastic cup to the body
Hope this helps
Posted on Jun 06, 2010
GE Profile Gas range 317B6641pool. The burners keep clicking even though the knobs are on the off position. Have to unplug it to stop the clicking. The burners do work when I turn the knob(s) on.
Someone slopped water or cleaning fluid into the spark switch... let it dry for a few days, but if the symptom persists order a new spark switch or harness by model # Help Me Find My Model Number RepairClinic com The spark switches are mounted on the shafts that hold the knobs near to the burner valves
Aug 28, 2016 | GE Kitchen Ranges
Microwave won't stop running
there's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Mar 30, 2014 | Samsung Microwave Ovens
Heater control knob not working
If you can pull the knob off the heat and look inside to see if the knob is broken out. if not you may have a broken switch.
Jun 23, 2017 | Volvo 940 Cars & Trucks
My maintenance light is still on even though i have changed my engine at 60,000 mileage, what could be the problem and how can i make it stop (toyota corolla 06)
To reset Maintenance light, do the following procedure:
  1. Turn the ignition to run (one position before starting engine).
  2. Ensure odometer reading is shown. Turn ignition off.
  3. While holding down the trip meter reset knob turn the ignition to run (one position before starting engine).
  4. Hold down knob for at least 5 seconds. The odometer indicates "000000" and the light goes off. If the system fails to reset, the light will continue flashing.
  5. Turn the ignition off and then start the engine to verify the indicator has been reset.
Apr 13, 2012 | 2006 Toyota Corolla
Hope this helps
Jun 05, 2010 | Water Tech Pool Buster Max Cg
Won't stop filling with water
Does the water continue to run when the washer is unplugged from power?  If it does, then there is something stuck in the inlet valve that is keeping it open.  Could be the result of mineral deposits.  If the water stops when unplugged then the water limit switch is defective.  Unlikely since the water still flows when control knob is in off position.
May 29, 2009 | Washing Machines
All 4 burners keep firing although the knobs are in the "off" position
It actually stopped doing it all by itself while we were waiting for a solution.
May 16, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Wirlpool elect range GR465LXLS, cant control heat on dbl burner
yes it is your control infinite switch the knob swicht that goes from 1 to 10 or min to max thanks from gilles
Mar 13, 2009 | GE Cooktops
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Water Tech Pool Buster Max Cg Logo
Top Water Tech Garden Experts
Dennis Key
Dennis Key
john h
Are you a Water Tech Garden Expert? Answer questions, earn points and help others
