Question about Compaq Presario R3000 Notebook
Computer keeps turning it self off
Any where between 30 seconds and 5 minutes
    Scholar:
  • 26 Answers
Hi vflood, This is usually due to a heat issue, possibly from accumulated dust inside the machine. Take the side off and, using canned air available in most electronics departments, blow the dust off of the cpu, heatsink, and fans as well as the ventilation areas. Then blow the rest of the dust out as well.
Also, if you have altered your operating system power settings recently, you may want to revert them to default.
Hope this helps, and please don't forget to rate/vote!
Posted on Mar 12, 2009
Self clean lock
Hello there:
Normally every body gets this almost right by cutting the power but there is a trick to this it can be done in 2 different ways depending on the unit
First unplug the unit and wait 15 -30 seconds then plug it back in and wait for 15 to 30 seconds then unplug it again and repeat this step 1 more time then upon the final plug in wait for 5 min and then unlock as you normally would.
now on the newer units the trick is to let it stand unplugged for 1 hour to allow the internal reset device to reset the appliance then plug it back in and then wait 5 min and you should hear it automatically unlock the appliance or you cn simply unlock it as you normally would
BUT REMEMBER DO NOT TOUCH IT FOR THE 5 MINUTES AFTER THE PLUG IN STAGE OR YOU WILL HAVE TO DO IT ALL OVER AGAIN OK
Hope this is very helpful for you please keep me posted on how this is going there is still more that i can show you but i wanted to start with the basics ok?
Best regards Michael
Apr 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Tv keeps self restarting after about 30 - 45
When lamp in TV become weak in result and consume more current then its rating , TV gets that symptom, on for few seconds/ minutes, shuts down and turns on itself.
Please replace lamp in TV as procedure is written in user manual of TV and its easy.
Let me know if you have further question.
Thanks.
Dec 13, 2009 | Sony KDS-R50XBR1 50" HDTV
When battery was unhooked, the security system came on and locked out the ignition. Car wont start.
 If you have the second ignition key's with you try it.  If not try this, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help.
Jul 17, 2009 | 2002 Chevrolet Impala
I have a 1999 s10 and changed the ign key and now it ran for awhaile and now security light stays on and truck dont start
Jul 16, 2009 | 2000 Chevrolet Blazer
When i try to start the car it wont turnover an it keeps blinking security on the dashboard
Your key has a computer chip in it that tells the computer that the person who owns the car is trying to start it. Sometimes the key will lose its memory and the car computer thinks your a thief with the wrong key. You may have to have a new key made from a code the dealer can aquire from the VIN number I believe.
Jun 27, 2009 | 2001 Pontiac Grand Am SE
1996 Pontiac Grand AM
Try this first, it takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself. Good luck and hope this helps, keep me posted, be glad to help
Jun 14, 2009 | 1996 Pontiac Grand Am
Trying to reset theft system
Can try doing a  relearn process, it is pretty simple and will take 30 minutes, if it'll work for you at all since your problem doesn't sound like a computer issue.
1. Turn on the ignition, with the engine OFF.
The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK.
Important:
and/or password.
ignition cycles.
Good luck and hope this help's. keep me posted if you need other ways to disable the passive lock system
Jun 03, 2009 | 2003 Chevrolet Malibu
My self cleaning oven door will not open, and keeps beeping and
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$%^@#
Apr 19, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Compaq Presario R3000 Notebook Logo
67 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
