ON OFF LED BLINKS TWO TIMES
WENT OFF SUDDENLY NO LIGHT OR SOUND AND LED BLINKS TWICE PERIODICALLY
  • 44 Answers
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain).
If you see this problem, you can buy a new power supply at www.shopjimmy.com or ebay. You will need the make and model, of your tv to order! Good luck, I hope this is helpful!!
Posted on Mar 12, 2009
Samsung tv MODEL UN40F6300AFXZA
Please un-plug the cable between the main board & the power supply board, apply AC power to the TV, if the back light come on, that means the back lights & the power supply are OK, then you need to replace the main board; if the back lights does not light up, mostly the back light LED strip(s) is bad.
May 24, 2017 | Samsung Televison & Video
55LM7600 Power suddenly went off. Attempt to power on via remote or on/off on TV and LED on 3-4 sec. then flashes twice then off. Any idea what this indicates?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 18, 2015 | LG Televison & Video
I have LG 32LC46-ZC TV. It suddenly stopped working, no picture, no sound. The LED blinks 5 times after turning on, but nothing else. Any suggestions?
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | LG Televison & Video
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
I have sony Bravia KLV -32V300A suddenly shut-off while I am watching power indicator went off and standby red light blinking 5 times then after 2 seconds off then red light blinks again 5 times and so...
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Mar 09, 2011 | Sony Televison & Video
LED bliks twice. stops for a second, and blinks
It's an error code. Check your manual under troubleshooting or call a Sony service shop with the model number and flash code.
Apr 06, 2010 | Sony Televison & Video
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
When i press power nothing happens except the standby light just blinks and doesnt stop.
What is the make and model number of your set? I can help you but I need that info, So I know where to start.
Jan 23, 2008 | Televison & Video
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Electro Med Services...
