Question about Maytag PDB2430A Dishwasher
Maytag Dishwasher- No water in the Tub???
I changed the water valve with no luck. If I pull the wires off and test them with a meter it reads 40 volts. if I plug the wires in and test them it goes to 0 volts???
  • 2 more comments
  • Patrick Newsome Aug 03, 2007
    No. I push the wash button and the dish washer acts like its waiting for water to enter but noting happends. then after a few minutes it starts the first cycle of washing but without the water?? I can fill the washer by hand and it will work fine??
  • Anonymous Dec 20, 2007
    I am experiencing the same probldem. My Maytag will not allow water to enter.
  • Anonymous Mar 06, 2008
    no water in the machine but it still goes thru the cycle
  • Anonymous Dec 06, 2008
    BUILT IN DISHWASHER MODEL MMV50000BAC WILL NOT PUT WATER IN DISHWASHER
After filling by hand it will go through the first cycle. every time it needs water i have to fill it by hand or it wont do anything.
Posted on Aug 05, 2007
  • 641 Answers
Does the dishwasher drain out water when you start its operation ?
Posted on Aug 03, 2007
  • Dov Dror Aug 04, 2007
    Fill water by hand and let us know what happen.
SOURCE:
Hi there. My Maytag MSE 760 FARS dishwasher is not filling, but the heating element is working. I suspect the pump has failed. What do I do?
what you can check,
  1. the float in the tub.their may be something caught under it
  2. the water valve,use a meter set to check ac voltage and check for 120 volts ac at the plug to it,if has 120 when supposed to fill valve is bad so long at it has water supply to it
  3. the float switch,use meter set to lowest ohms setting and remove the 2 wires on float switch and check for continunity(zero ohms) if meter reads OL replace float switch
  4. the control,check for 120 volts ac to float switch when supposed to fill, if 120 at fill portion yet no fill ,replace control
  5. water supply,if uses flex tube something in cabinet under sink may have pinched water line
Good luck,i hope this helps
Gene
Aug 02, 2011 | Maytag Dishwashers
Not getting water to go Got washing
Their are a few things that will prevent it from filling
  1. The float in the tub has something caught under it..pull out lower rack and check
  2. The float switch is bad...pull off kick plate below door and use a meter set to a low ohms setting and when checking switch if good will be zero ohms. OL if bad
  3. the control is bad and not sending power to float switch..use meter set to volts ac check for 120 volts ac to switch. to do that place one meter lead on a wire on float switch and on the a metal peice (leg,frame ect) and check for 120 vac, if 120 vac at switch the control is good if not replace control, this check must be done when d/w is supposed to fill( usually at the begining of a cycle)
  4. water valve.. use meter set check vac and check for 120 vac to plug(one meter lead on each wire) when supposed to fill, if 120 vac,needs inlet water valve
  5. water from house plumbing is restricted...loosen supply line nut and check for incoming water
Gene
Aug 01, 2011 | Maytag Dishwasher
Water temperature is not that hot any more dishes stay dirty after 3rd cycle
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Testing a heating element
Note: Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Locate your dishwasher's heating element. Open the dishwasher door and look into the tub. It is the thin, circular tube at the base of your dishwasher. It may or may not be covered. If it is covered, remove the lower dishrack, and then remove the cover.
Your heating element is going to have two metal terminals. One at each end. Each terminal reaches downwards, into the base of the dishwasher. Mentally mark the area where each terminal enters the base of the tub.
Now you need to gain access to the heating element's wiring. You can do this by first removing the lower kickplate panel of the dishwasher. There will be at least two screws (but maybe four) holding the kickplate panel in place. They are located either on the top or the bottom of the panel. If the screws are located on the top, you may need to open the dishwasher door in order to gain access to them. Close the door to remove the panel, though.
Now look into the lower access area that you have just uncovered. Pinpoint the area where the heating element terminals extend through the base of the dishwasher. They will each have a wire connected to it. Label each of the wires so that you will be able to properly reconnect them later. Now you can pull the wires off the terminals.
Each wire is connected to a terminal using a slip-on connector. Grasp the connector and pull on it firmly.
DO NOT pull on the wire itself. Pull only from the connector. You may decide you need to use a pair of needle nosed pliers to help you.
Use your multitester (aka multimeter) to test the heating element for continuity. Set the device to the ohms
setting x 1. Touch each meter probe to a terminal. You should receive a reading somewhere in between infinity and zero. Because of the variety of makes and models of dishwashers, it is quite difficult to say exactly what the reading should be for each and every possible model. However, if the test you conduct produces a reading of infinite resistance (meter's needle does not move), then that is indicative of a faulty heating element, and you should replace yours. Similarily, if the test you conduct produces a reading of zero resistance (meter's needle moves to the other extreme of the scale), then that is also indicative of a faulty heating element, and you should replace yours.
You do not have to remove the heating element from the dishwasher in order to test it. Just make sure power is not getting to your dishwasher before you conduct the test.
Jun 13, 2011 | Dishwashers
When we turn on the dishwasher there is no water entering the appliance..then it cycles to drain the water and I reset it so the pump doesnt burnout...what could this possibly be and is there some...
hi Mapletonmob.
this is all i could find out.
A dishwasher that will not fill with water can be frustrating and repairing it through a serviceman can be expensive. Even for someone who may not consider themselves handy, repairing a dishwasher is not a difficult process. Below we've provided you with a list of the most common parts that fix a dishwasher will not fill with water. Use this information to help troubleshoot which part is broken
The water inlet valve is used to fill the dishwasher with the proper amount of hot water and is controlled by the timer or electronic control. The valve will be located behind the lower access panel and will have two wires attached to it, an outlet hose to the tub and a hot water inlet from the household supply. If your dishwasher does not fill then you should first check the inlet supply to verify that you have enough water pressure and that you have power going to the valve during the fill portion of the cycle. If these conditions are met then the valve is defective and should be replaced. If you do not have power to the valve then you should look at the float switch, the timer or electronic control or the door switches as a possible problem. All of the electrical checks can be made with a multi-meter.
A malfunctioning float could cause the dishwasher to not fill with water. The float is located at the bottom of the dishwasher tub and acts as a safety device that prevents the dishwasher from over filling with water. The float rises with the water level in the dishwasher and when the proper level is reached, the float will trigger the float switch to turn off the water inlet valve. Check that there is no debris or foreign objects that might restrict the vertical movement of the float and that it engages the float switch located beneath the tub.
The float switch sits below the float, beneath the dishwasher tub. When the float switch is triggered by the float, power to the water inlet valve is interrupted and it stops the flow of water into the dishwasher. Verify that the mechanical action of the float to the switch is operating properly and that the wire connections are secure. To check that the float switch is working properly, remove the wires and test for continuity with a multi-meter.
The door switch is a simple on/off mechanism that prohibits the dishwasher from operating when the door is open. If the door switch or switches are malfunctioning the dishwasher will not fill with water. This door switch mechanism is typically located behind the door panel at the top of the door. To verify the operation of the switches you will need to separate the inner door from the outer door and then remove the wires from the switches and check for continuity with a multi-meter.
We've identified the most common parts that can cause the dishwasher to not fill with water, but there are other parts that could be at fault. If you are unable to fix your dishwasher with the information above,
if none of the above work you might have to call someone out to have a look at it.
Nov 29, 2017 | Maytag Dishwasher
Water not heating therfore dishes not washing or drying right.
Well the water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Please follow the below steps to check the heating element in your dishwasher -
(Note.Disconnect the power source to your dishwasher before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.)
Good Luck!!
Thanks
Mar 02, 2010 | Hotpoint Dishwashers
My dishwasher will drain but will not fill up with water ?
Hello there
Specific symptoms include: Little or no water enters the tub . To find the cause, first check to be sure the water is ON.
always “zero” the ohmmeter before making any continuity checks on dishwasher components. . When making continuity checks with the volt/ohmmeter, always turn the electricity OFF at the circuit breaker panel. Live voltage checks will damage the meter movement.With the water ON, remove the lower panel. Place a towel or shallow container on floor to absorb water. Loosen the nut that secures the dishwasher water tubing to the inlet port of the water inlet valve. If water collects immediately in the towel or container, it can safely be assumed that the water pressure is adequate and the plumbing system is not clogged . If little or no water collects in the container, the water line gate valve could be defective or there is a problem in the plumbing system.
Turn the water OFF. Remove the lower panel. Loosen and remove nut that attaches water tubing to water inlet valve inlet port. With tubing removed, check for corrosion and debris that has accumulated inside the tubing and inlet valve inlet port. . Turn the water supply ON. Select a cycle on the timer dial where the dishwasher starts to fill with water. If it starts to fill with water — you fixed it. The problem was corrosion inside the water tubing or inlet valve water inlet port. If the dishwasher still does not fill with water, an additional electrical check will have to be made.Next, test for electrical power to the water inlet valve from the dishwasher timer assembly. Using the volt/ohmmeter, set the meter on the 150-volt scale and attach the two test leads of the volt/ohmmeter to the two terminals of the water inlet valve solenoid coil to be checked. Turn the water ON. With the test leads attached to the solenoid terminals, select a cycle on the dishwasher timer dial where the dishwasher starts to fill with water. Push in or pull out the timer dial. You should get a voltage reading of 110-125 volts A/C on the volt/ohmmeter scale. If you get a reading, this would indicate that electricity is available from the dishwasher timer assembly to the water inlet valve.However, the absence of water flow means the water inlet valve is defective
Dec 31, 2009 | Maytag Dishwashers
Maytag Dishwasher Leak
HI. this is a inlet assembly issue. The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow. There are two wires (four, if it has two solenoids) connected to the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. If your valve has two solenoids, test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the dishwasher is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
***(((NOTE-- It i possible that the valve housing has cracked as well. make sure that the hoses are connected properly during your testing. If there are no hose issues, this will be a defective valve assembly)))
Sep 12, 2009 | Maytag MDB6000 Dishwasher
Dishwasher will not fill up with water
check the following- remove the wires from the fill valve.close the door and start the unit.u should read 120 v as u start the unit.if u read 120v then fill valve is bad.if not then chk and make sure the float is sitting completely down and float sw is closed.the power to fill valve goes throug this sw.if all is ok and still there is no power then u may not be getting power from cntrl board and control board could be bad.but that rarely happens.turbidity sensor does not affect the fill operation.good luck.
Aug 16, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
No water in dishwasher?
Hello, your problem is going to be with the inlet valve, there is a solonied on top of the valve that has shorted out, the way to test this diagnosis is remove the panel at the bottom of the dish washer..locate the inlet valve normally on the front left under the washer, remove the 2 wires from the valve (being sure to cut the power off to the dishwasher while you do this step) using a volt meter isert the probes into the connectors on the wire then turn power back on, now run a wash..after a minute or so you should see 110v on the volt meter...if this happens your valve is bad you will have to pull the dish washer out and replace the valve. Good Luck!!! If you have any other questions or concerns please feel free to comment again. Mike
Jul 24, 2009 | Maytag 24 in. MDBH950AW Built-in...
Agitator wont spin
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Nov 13, 2008 | Maytag PAV2300 Top Load Washer
Maytag PDB2430A Dishwasher Logo
141 people viewed this question
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
