Question about Toro Garden
Toro Mower model 30176 blowes fuses
It blowes the fuse
  • 147 Answers
SOURCE: toro self propelled mower will not move
This is a very simple solution, When you pull the lever it simply pushes a pulley into the belt to make it tight. Most of the time the belt has come off or maybe the cable broke. Turn the mower over and you will see the belt. My money is on the belt off.
Posted on Nov 06, 2008
lilmikew99
  • 122 Answers
SOURCE: Toro mower won't start. No sound when I turn key.
definately connection some where i would use a volt meter and make sure where power is and make sure it is getting too where you need it, if its getting too the soliniod or not then too the starter.
Posted on May 10, 2009
  • 41 Answers
SOURCE: turn the key for electric start,nothing happens
If you never used the starter,You need to have it checked, possible that it i froze up. Or brushes in starter arn't making contact. Also check connections. Good Luck
Posted on May 19, 2009
  • 320 Answers
SOURCE: My Toro LX425 keeps on blowing 20 amp fuses when I
a fuse will blow if: a positive wire is being grounded to the frame or two much current is being passed thru it.
Posted on Jun 29, 2009
  • 4 Answers
SOURCE: Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Posted on Mar 03, 2010
My toro keeps blowing fuses when i turn the key i have a toro 14-38hxl wheel horse rider
its either getting to many amps which will blow fuses
you might have a short (positive wire touching metal)
fuses are not right ie: 10 amp when should 15amp
trace the leads from the key switch (turn it on) to your coil check that they are good
the coil might be faulty
hope this helps
Sep 30, 2011 | Toro Lawn Mower With Toro Power Tools
I have a 05 Toro 44in ZTR with a 19HP Kawasaki engine with under 300 hours the main 30amp fuse keeps blowing when I turn on the ignition switch on. I noticed when I disconect the PTO switch the fuse dousnt...
sounds like your electric clutch is prob bad check to make sure wires are not bare touching something, the clutches do go bad eventually like any other electrical part, disc the pigtail and try fuse, if it blows then I would consider a clutch
Jul 27, 2011 | Toro Zero Turn Rider 74833 Lawn Mower...
Water and wet grass get into the battery compartment of my Toro Key Start self propelled lawn mower and blow fuses. All Toro repairman did was replace corroded battery, replaced fuse and wiring harness,...
"Is this a design flaw by Toro?" (sic) Well, it indeed maybe, it definitely, isn't helping the situation. Here's what to do, get some Mesh, and fasten it across the opening, this will stop most things from gaining egress, and protect what is behind, If that's not sufficient, then perhaps a Plastic,sheet (perhaps if required some holes in it). fastened, across the aperture, will work. In any case I have no doubt, you have the idea of what to do to remedy this situation.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
My Toro LX425 keeps on blowing 20 amp fuses when I am mowing the yard. Why is it doing that?
Jun 28, 2009 | Toro Lawn Mower With Toro Power Tools
Turn the key for electric start,nothing happens
May 19, 2009 | Toro Lawn Mower With Toro Power Tools
May 08, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
27 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
