Question about Dryers
Kenmore dryer model 110.87086601 lint sensor blinks
  • 148 Answers
SOURCE: I have a Kenmore 110.74812200
its the flame sensor,or the coils on your gas valve
Posted on Jul 08, 2008
  • 88 Answers
SOURCE: ''clean lint filter'' light is on- dryer will not work
is the door trigger working properly if its faulty then the dryer will not work
Posted on Jun 05, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
SOURCE: Kenmore HE4 Dryer leaves clothes wet
From the techincal document found in the dryer bottom panel
TEST #4a Dryness Level Adjust
NOTE: If the customer is complaining about the clothes being damp and the moisture sensor passes TEST #4 "Moisture Sensor Test- step 3, then the total dry time can be lengthened by changing from a "Lo" for short auto cycle to "Hi" for longer auto cycle.
1. Activate the Diagnostic Test Mode. Press the following button sequence: MORE TIME ~ LESS TIME -+ MORE TIME --+ LESS TIME - all within 5 seconds
1. In diagnostic test mode, press and hold the Auto Dry Level key for 5 seconds. The dryer will beep and the current auto cycle mode will be seen on the display. The factory default setting is "Lo".
1. To select a different auto cycle mode, press the Auto Dry Level key again. The dryer display will flash and show either "Hi" or "Lo"
1. With the display flashing the selected auto cycle mode press the Start key to save the setting and exit diagnostics (the Start key in this mode does not start a drying cycle). The result will be stored in EEPROM of the control board.
SO EASY JUST TOOK ME 3 YEARS TO FIND IT
Ross
Posted on Nov 22, 2009
SOURCE: Kenmore Dryer, model 86950100 PARTS
I was just looking for a part for mine, too. On the tag inside the front door is the pre-printed prefix 110. that goes with the 86950100 that's printed later. So, I entered 110.86950100 and found the information for my model.
My unit has been working reliably for many years now, and some parts are not available anymore. I think I bought it in about 1985. I replaced a thermal cut-off switch in 2009 for $15 locally. I also have a matching washer. I've never had any failures with it. Bear in mind that I was single for 20 of those years with only a few girlfriend-hours on them. :-)
The direct link to Sears parts for my specific model is http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.86950100.
Hope this helps.
Posted on Jan 22, 2010
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
Kenmore dryer code ad
The "Ad" in the display indicates that the dryer is in the Auto Dry cycle.
The dryer will run in the Auto Dry cycle until the moisture sensor bars detect no more moisture in the garments being dried. The machine will then go into a cool down period and then end the cycle.
If the dryer is getting unusually hot, I recommend checking for a restriction in the air flow. Make sure that your lint screen is properly cleaned before starting every cycle. Check the flexible vent hose behind the dryer for a kink or a restriction. Check the exhaust ducting to the outside of the house for lint build-up or a restriction. This may help the dryer perform properly.
Sep 16, 2014 | Kenmore Dryers
Why does dryer start run a little beep 3 times cut off
Really you need to provide your model number. but that said... the number one cause of a dryer shutting down after a short warm-up is a blocked exhaust outlet. Dryers have a sensor that checks the exhaust temperature... if its not moving the hot air out side than it over heats and trips the sensor which will shut off the dryer for safety (no fires please!!). So check your exhaust outlet outside for lint blockage... check your exhaust hose/pipe for kinks where lint can build up and of course always check the lint screen for blockage.
Aug 05, 2014 | Kenmore Dryers
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
Kenmore he3 model 11082822102 the check lint
remove back panal and clean hose to sensor.
Nov 19, 2009 | Kitchen Ranges
Will not heat
glow bar igniter ... - thermal fuse ( not all models ) ... - coil on the gas valve ... - gas valve ... - thermostats ... - motor heat switch ... - timer ... - selector switch ... - sensor ... All these will cause this problem.
Mar 22, 2009 | Kenmore 74672 Gas Dryer
PF indication (Power Failure) and dryer digital light up but will not start
check your owners manual for clearing error codes in trouble shooting on theese electronic models lots of time you have to clear the codes to go back to normal ops by pushing certian buttons on kenmore i dont know which ones they are usaly its clear/cancel buttion some times you have to holld them so many seconds just unplugging it will make it think it has another power failure
Dec 26, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
