Question about Maytag 7.0 Cu. Ft. Electric Dryer
What's your problem?med400vw dryer - Maytag 7.0 Cu. Ft. Electric Dryer
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    Dryer not powering/turning on
    Investigate these areas if your dryer is not starting: Proper Voltage from the House Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in. Door Switch If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. Start Switch A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again. Thermal Fuse A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. Thermostat A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective. Timer Motor Your dryer's timer will not function properly if its motor is malfunctioning. Open up your dryer's cabinet and locate its motor. Test the component. If it is not functioning as it should, replace either the motor itself, or the entire timer assembly. Motor A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor. For more info see the following link: http://www.partselect.com/dryer+dryer-wont-start+repair.htm
    Aug 05, 2012 | LG DLG2532 Gas Dryer
    Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
    There can be many reasons why your dryer will not start or turn...
    The most common causes are the belt breaking or jumping off, or the motor goingbad...
    Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
    Dryer Repair - The Dryer is not Turning
    Dryer Repair - The dryer will not start
    heatman101
    Sep 19, 2011 | Kenmore Dryers
    Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
    heatman101
    Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
    Dryer will not start, it's just dead. Checked wires and tightened them?
    heatman101
    Jul 03, 2011 | Maytag PYG3200 Dryer
    Dryer will not turn on
    heatman101
    Jun 25, 2011 | GE Dryers
    Tumble dryer does not heat up during cycle
    Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
    heatman101
    Jun 07, 2011 | Miele Novotronic T230C Electric Dryer
    When I push start on my dryer it hums, the drum rotates ever so slightly then it stops, almost like it is stuck.
    heatman101
    May 10, 2011 | Bosch Dryers
    Dryer not starting display panel working fine
    heatman101
    May 01, 2011 | Maytag Dryers
    Maytag 7.0 Cu. Ft. Electric Dryer Logo
    24 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
