Question about Whirlpool Dishwashers
Whirlpool dishwasher model no GU2300XTVQ1 will no completely drain after cycle unless I press cancel
I believe I have out the problem I am having as clear as I can
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
  • 338 Answers
SOURCE: Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Posted on Nov 25, 2008
rickzilla
  • 706 Answers
SOURCE: Dishwasher will not drain
Hello Tom,
Glad that you were able to find something out of place in the check valve ( like the gasket) which in turn was restricting the ball in that check valve from being in the right position. I'd be willing to bet that your problem is solved..
Regards,
Rick
Posted on Dec 08, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: When the dishwasher timer gets to the number 1 is
Hello, welcome to Fixya. Based on the info you provided, especially the error code "1" and running a very long time or forever, I know what the problem is, though you may not like it. I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line. Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher. That is just a suggestion out of courtesy however... If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to. The reason your dishwasher is displaying a "1" is the control has detected a heating error. It isn't the countdown time. The error code is displayed by the number "1". Here`s the most likely reason why it has detected the error... Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry. The issue with your Bosch dishwasher likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ). This is why it runs forever unless pressing the two buttons for "cancel". To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s at "1" ( because it can`t heat to advance or until canceled ) trying to heat the water. **Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)** Replacing the complete electronic control will certainly remedy the problem as well. The part is available at most brick & mortar parts stores or on-line vendors such as "repairclinic.com" , "searspartsdirect.com" , "apwagner.com" to name a few. **Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.** Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied. Thanks again and good luck. Macmarkus :)
Posted on Jun 17, 2010
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Hi: How do I turn off the beeping signal when the cycle is completed on my Bosch dishwasher? It's a fairly new model, with the control on the top of the door. Thanks, Jean Ferrario
I just tried this and it worked.
The Cycle Completion Signal
this Cycle Completion signal is a tone that sounds to alert you when your dishwasher finishes washing and drying your dishes. You can either disable the tone or set the volume.
to activate:
· press and hold the right “Cancel Drain” button then press and hold the on/off button.
· When the light on the “Cancel Drain” button you are pressing illuminates and the tone begins to sound, release both buttons.
· press the right-most “Cancel Drain” button until the tone is either at the desired volume or is silent.
· press the on/off Button. the Cycle Completion signal is now set.
Jan 22, 2009 | Dishwashers
Whirlpool dishwasher won't start
I have had the same problem with my dishwasher. I.e., the buttons don't respond (no LED) when you press them. Only the "Cancel/Drain" light works and the dishwasher reacts to cancel/drain. I found a diagnostic in the kick panel that has you press; "heated dry, normal, heated dry, normal" within 6 seconds and the washer goes through a diagnostic. All of the tests perform as they should and at the end the washer works again. I don't know why unless doing this resets the circuit board. Does anyone know?
Jan 04, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Jun 29, 2007 | Whirlpool 24 in. DU915PWP Built-in...
Dishwashers Logo
44 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
