Question about Amana Kitchen Ranges
Amana ags781ww range oven will not light
Oven will not ignite
duby1990
  • 367 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
SOURCE: Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: Igniter of Gas Burner does not ignite gas
Does your Amana range get very very hot on the exterior part mostly by the control panel?
Posted on Aug 21, 2009
  • 80 Answers
SOURCE: Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Posted on Oct 03, 2009
jsrock516
  • 5911 Answers
SOURCE: how to replace oven igniter on amana ACS3350AS gas
The following link explains step-by-step how to replace an igniter in a gas range:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The replacement process is pretty standard with nearly all gas ranges. You can go to appliancepartspros.com for reference drawings to assist you as well. The oven burner assemblies are listed under the "Cavity" section.
If you have not purchased an igniter yet, the part number is AP4041245. If the connector plug does not match, there should be instructions that direct you to splice the wires using ceramic wire lugs. DO NOT use standard wire lugs. They will melt due to the high heat in the oven. The wires and connectors on these oven igniters are heat resistant. If ceramic lugs are not included with the igniter, you may have to purchase them separately. The part number is AP3440631.
This is a fairly simple repair, but if you have questions, please let me know. I hope this helps you.
Posted on Nov 15, 2009
Oven wont light
Chances are you have an oven igniter that is not working - pilot lights are no longer used because of energy consumption. That igniter needs to be replaced for the oven to light up and function.
Sep 08, 2015 | Amana Gas Stove Range Oven Ignitor Igniter...
Automatic burner lighter is not working on my gas range, Amana The Big Oven
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 26, 2011 | Amana Microwave Ovens
Amana oven wont light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wrtww
Sep 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana Gas oven does not work.
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Jul 15, 2010 | Amana RanARG7302 Gas Kitchen Range
My Amanda gas oven Model no. AGS781WW is not heating up in the oven, nor does the broiler come on. The electronic ignition glows, I don't smell any gas in the oven. The cooktop comes on fine.
even if the ignitor glows it may not be getting hot enough to light the gas. if it does not get hot enough the gas valve should not open. try changing the ignitor, usually 30 - 60 dollars.
Jun 21, 2010 | Ovens
Amana stove, oven igniter works but oven wont light
although the bake ignitor appears to be glowing, it probably does not glow with the intensity it needs to open the safety valve assy, VERY common problem, go aheadand replace the ignitor, this will correct your issue
Feb 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Amana agr5735qds oven will not light.  broiler works as do all the burners.
There are two igniters in your oven one for bake and one for broil. The bake igniter very likely needs to be replaced. Igniter part number is 70080764.
Dec 13, 2008 | Amana AGR5735QDS Gas Kitchen Range
Kitchen Ranges Logo
52 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mike Carew
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
