Question about GE 60-511-01-95R - ITI Wireless DS 924 Infrared Motion Derector
How to change battery ITI Wireless DS 924 Infrared
I have just got a sky+hd 2tb box installed, i have a wireless transmitter and sender that i use to watch sky upstairs in my bedroom, i can get sky upstairs through the wireless scart connector/video sender...
You need to find out if you remote is infrared or radio frequency. If infrared then there are remote extender devices that you can purchase to use your remote. If it is RF, then your search would be the RF remote extender box.
Jul 02, 2014 | Computers & Internet
Error codes 51099
This code means that your wireless signal is not compatible with your DS. If you are using WPA/WPA2 for securing your wireless internet then you will not be able to use your DS on this signal. I would suggest changing your wireless signals passphrase to WEP so that you will be able to use your DS without any problems
Aug 19, 2011 | Nintendo DS Console
Once i try to search fo an access point it says, the access point's security settingsare notsupported by the ds and we tried to unlock the wifi network
After setting and saving the settings on your wireless router to disable the security on the wireless network, did you try rebooting the DS? The wireless settings can get stored in the DS memory, so after you make changes to your network you may need to restart the DS. That should fix the issue.
Aug 14, 2011 | Nintendo DS Lite Console
The access point security for the wifi are not supported what do i do
you can either change the wireless security to something that the DS supports (different models support different wireless settings check the Nintendo DS site) or you can turn off wireless security all together, if you go for the later, i'd only do it temporarly and after you finish using your DS on the internet turn wireless security back on.
Mar 05, 2011 | Nintendo DS Console
We have an error code 51099 on the DS. Could you please tell us how to correct this. Thanks
This code is generally attributed to the DS not finding a connection to the internet using Wifi. The DS does not support WPA security. Change the security on your wireless router to WEP or No security.If you donot need the internet on your DS then change the internet wifi off. Another thing is to change the router to b/g or mixed mode. If you are using wireless N only then the DS cannot find and use the wireless network.
Jan 17, 2011 | Computers & Internet
Wi-fi
I am going to take a guess here - you are trying to connect a DS lite to your wireless network - the DS only support WEP security not WPA. Most wireless routers will default to WPA security. You need to log into your router and change its security to WEP. Details are dependent on the router make and model. If you need details on haw to change the wireless network please let me know.
Dec 18, 2010 | Nintendo DS Lite
Acer kg-0766 connect
Did you push the synch button under the keyboard after battery replacement as well as the one on the Infrared sensor on the PC?
Mar 09, 2010 | Computers & Internet
I need a manual so as to install wireless. Where
Straight from the official Dell web site, here is a clickable (and printable) link to the owner's manual for the Dell All-In-One 924 Inkjet Printer.
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
I hope this helps!
CBR2009
Aug 11, 2009 | Dell 924 All-in-One InkJet Printer
Looking for technical manuals
I talked to 3 different departments at ITI, they all say you can't get them anymore (sales, tech support, and repair) No one even has a number for a refurb equipment company.
LINE CARRIER POWER TRANSFORMER
: : ITI part #60-145-235 Canada part #60-366
: : The power transformer supplies a DC voltage of approximately 13 to 14 VDC (unloaded) to the CPU through terminals 1 & 2. Additionally,it contains the line carrier circuitry for the Wireless Interior Siren through terminal 3. The AC power indicator voltage for the CPU is carried through terminal 4.
: : The Transformer is fused with a 400 mA fuse on the primary side of the transformer. Replace only with a 400 mA 250V Time Lag Fuse (ITI Part #33-023).
This is all I could locate, hope something here helps.
please leave rating. thank you
May 06, 2009 | Computers & Internet
GE 60-511-01-95R - ITI Wireless DS 924 Infrared Motion Derector Logo
50 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
