Question about RCA RT2250 System
When i unplug my rca rt2250 home theater system. the green light comes on on the right side. then goes off. everything works good after that speakers sound good. but once in a while that green light comes back on and the speakers cut out. then i got to unplug it to reset it and it will work again. sometime works for hours and sometimes 30 minutes. what could that be!!!!
  • 2 more comments
  • cirwin7224 Mar 12, 2009
    were do i find the parts for my rca rt 2250. like the amp ic and what does it cost if i replace it.
    can you help me locate this part on the board so i can replace it. im not sure what im looking for
    how do i now what ic it is is there a number on board to look for
  • cirwin7224 Mar 13, 2009
    i will try to locate ic number for you. its been working all day.
  • 905 Answers
This is the amp IC and while unplugging and plugging it in again helps reset the IC for a little while , it will eventually completely quit and will need replaced
make sure that none of the speaker wires(bare wires) are touching or look like they might be where they are connected at
also if turning up the volume makes it cut out or sound bad then this will also indicate a bad amp IC
Posted on Mar 12, 2009
  • 2 more comments
  • jason Mar 12, 2009
    You would have to get the number off of the IC on the heat sink and you can try to cross reference it here http://nte01.nteinc.com/nte/NTExRefSemiP...$$Search?OpenForm
    this is an electronics parts supplier http://www.nteinc.com/
    and there is a link button for locating a nearest distributor (parts store)
    sometimes CHIPS and IC's are just not available to the public untill a later date or sometimes not at all , but you can check the numbers there , if not then I'm sure there will be one online.
    if you have trouble let me know
    power to the amp and audio in on the circuit should be checked for low or other possible electronic component replacement
    they are the IC's screwed on the big heat sink and may start with "TDA" for thier identification number, I have been trying to locate a service manual or schematic for it to see what IC they used,but I haven't found one , free anyway
    if you can get the identification numbers on these IC's for me i'll help in trying to locate it
    the speaker output circuit will lead back to the amplifier IC
  • jason Mar 13, 2009
    it might be the tda7293 http://www.datasheetcatalog.com/datashee...
    but i'll wait for you to check this so I can make sure you get the right file and info
I have a RCA RT2250 and I have a green light on a circuit board
Check the solder connections on the seven voltage regulators found in the center of the receiver on the heat sink from front to back (not the amp board) they are on the main board. The green light on the DSP board (back right side) is an error light. You can reset the receiver by pushing power then stadium then night then dsp off then club after unplugging the receiver and plugging it back in.
Hope this helps,
JohnW
Jan 10, 2009 | RCA RT2250 System
Power but no sound
hook up the antenna at the back and try to tune-in to your favorite radio station.
read the description at the back of your rca rt2250, how to connect your antenna.
connect it properly and raise up the antenna, put it where the signal is good.
Feb 17, 2008 | RCA RT2250 System
Rca 2250
Sounds like your right side output is shot. And yes it can be fixed, but the cost factor would be higher than what you paid for the set itself. First see if your inputs are working correctly, this also could be your problem. Check all your connections.
Dec 29, 2007 | RCA RT2250 System
Rca Rt2250
just want to know how I can hook up my 8 ohm speakers to this receiver
Nov 13, 2007 | RCA RT2250 System
RCA RT2250R P.O.S. no sound
The blinking speakers mean the unit is waiting for an input. It could be that the input section is faulty, but I need more details.
What input is being used?
what speakers are connected and to where?
what is the audio source?
May 20, 2007 | RCA RT2250 System
Continous Buzz/Pulse from speakers No other sounds come out
Sounds like you have an open filter capacitor. Your gonna need to look at the b+ and figure out what cap is bad. A circuit diagram would assist you in this repair. If you have no experience with electronic repairs then your gonna need a pro to assist you with this as there are no user replaceable parts inside this unit. Sorry Man. Good Luck
Jun 26, 2006 | RCA RT2250 System
RT2250R
hi check all!! connections( RCA's, speakers ) make sure the DVD and TV are connected to right inlets here is the home page of your system http://www.rcaaudiovideo.com/Cultures/en-US/ModelList.html?CategoryID=DVD+Home+Theater+Systems check out the manual maybe there is something you havent told ... it can help you good luck
Feb 18, 2006 | RCA RT2250 System
RCA RT2250
Make that 3. There must be some kind of date chip in the thing
Dec 22, 2005 | RCA RT2250 System
RCA RT2250 System Logo
564 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
