Question about Cooper Wiring Devices Electrical Supplies
How to wire Cooper ms35 outdoor motion sensor light
3 Suggested Answers
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Posted on Jan 29, 2010
SOURCE: I have a cooper 6107
Cooper 6107 instruction sheets:
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/instruction_sheets/469mt_pta_rev._a_.pdf
http://www.cooperindustries.com/content/dam/public/wiringdevices/products/documents/spec_sheets/std_sensswitch_spsht_4_10_anp.pdf
3-way installation shows two motion sensor switches.
Instructions do not show 1 motion sensor and 1 ordinary 3-way switch.
Also note the maximum load rating is 500Watt
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical work or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Sep 09, 2011
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Instructions to wire a cooper light model number MS35 rain tight
1) Copy following link for wiring diagram of 2-light outdoor motion sensor.
http://waterheatertimer.org/How-to-wire-switches.html#motion
2) Existing light fixture will have 2 wires: Connect wiring as shown on link above, then keep light switch turned ON.
Jan 21, 2013 | Hardware & Accessories
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
I have a cooper 6107 motion sensing 3 way wall swithch and I am using it to replace a three way non motion sensing switch. I have it wired correctly, green to ground, black to common, and the red and brown...
Sep 09, 2011 | Cooper Wiring Devices Motion Sensing...
I have the cooper K6107v-l motion sensor. Is there a way to adjust the time delay? The device shuts off after about 3 seconds, I want it to stay on for 5 minutes.
under the cover,of the device ,pry with a small screwdriver ,there is 3 controls side to side is the outer or wdth of range then in the center is time ,turn it clockwise you can adjust it up to 20 minutes
Jun 10, 2011 | Cooper Wiring Devices Motion Sensing...
How to wire a cooper industries 6107 3-way motion detector switch
Jan 28, 2010 | Cooper Wiring Devices Motion Sensing...
How do you connect a motion sensor light switch to a chord that can be plugged into a wall?
hmmm lets see... what is the motion sensor controlling?... lets assume it is a lamp with a plug on it. so you need to wire the motion sensor so that it has a male plug on one end and a female plug on the other. lets also assume it is two wire lamp cord and a two prong plug. Take a standard extension cord and split off one of the wires and cut it, attach one of the motion sensor wire to one of those wires and the other motion sensor wires to the other wire.. so the motion sensor is splitting on of the wires.. oh this would be so easy to draw...
Nov 05, 2009 | Cooper Wiring Devices ACE6001V-K "ACE"...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Open Questions:
Electrical Supplies Logo
81 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
