Question about John Deere Garden
Lx255 stalls when brake released
Stalls when brake released
Why does engine stall when brake is released?
When the brake releases and it stalls right out, usually a sign that the coil is getting the signal to stop the engine. You have a faulty ground or faulty coil wire. Check safety switches as well... if there's one under the seat, unplug it...
Nov 02, 2015 | Garden
Goes dead when disengaging brak
Lawn Tractor stalls after engaging blades or releasing brake ...
www.shopyourway.com > Manage My Life > Questions
Scenario 2: Engine started, as above in scenario 1 and manaul brake lever is engaged. Again ... Lawn Tractor stalls after engaging blades or releasing brake .... I am goingto replace that anyway but it almost seems my problem is electrica
Sep 14, 2015 | Garden
Toro ss4235 release brake stalls when arm pushed in
bad check valve or buy pass screen dirty take to shop 100.00 for by pass to fix 100.00 for check valve to fix
Sep 03, 2014 | Toro Garden
Have 17.5hp rider. Starts and ideals ok with brake on. As soon as brake released it stalls. Tuned up and replaced the seat switch. Any ideas?
Hi, It would be more helpful to know make and model of lawn tractor. But lets try take some steps. I assume the tractor is in neutral when started and in gear when release brake pedal? So does it stall when you release brake pedal when in neutral? If not then its not. We can start checking why. Does it stall from working the engine or just shuts off? If it just shuts off then it is a switch. If it truly stalls then a park brake is on or tranny is jammed. Jack drive tries off the ground. See if you can turn tires in neutral. If you can't look for a park brake lever. And while jacked up check all your belts. To see if any are pinched. That is another problem sometimes. The drive belt gets pinched.
Jul 04, 2014 | Garden
What would cause a 1989 nissan sentra to smell like burning rubber and then stall out but not over heating
clutch plate to tide ,brakes not release probable or the hand brakes not release right down.,plastic material on the exhaust system .electrical wire shortage .
Sep 22, 2012 | 1989 Nissan Sentra 4 Door
1998 Corvette with manual transmission. when letting clutch pedal out, car stalls every time either in 1st or reverse
Give it more gas before letting the clutch out? Release the parking brake? Check for binding brake/parking brake parts if brake is released? Dammaged differential?
May 26, 2012 | Cars & Trucks
Simplicity mower stalls when brake released
There is another safety switch connected to the parking/service brake. Check that one too. Sounds like its the one.
Jun 22, 2009 | Garden
Engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Apr 21, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
