Question about KitchenAid KHHS179LSS Convection / Microwave Oven
No power on kitchenaid khms2056sss
No power
Makes random beeping noises all hours of the day & night. Annoying but wondering if something is wrong or if there is something we can do to stop it? Works fine otherwise!
I have never heard of that happening before. I think you need to ask Kitchenaid direct. Once the machine is off and dead, it should stay quiet until you press a button or open the door.
http://www.kitchenaid.ca/en_CA/contact-us/
Help Contact Us KitchenAid
Mar 28, 2016 | KitchenAid KHMS2056SSS Microwave Oven
Having touch-pad problems with my KitchenAid KHMS2056SSS-0 range hood microwave. It's an intermittent problem where the touchpad activates itself and activates menu items.. and beeps each time. Resetting...
Usually the top vent front panel is held in by two screws and or clips, Get those off and the bottom of this peace should un hook, unless there are screws there also. if you can get this far, the rest will be obvious.
Oct 20, 2013 | KitchenAid Microwave Ovens
Display says door is open but its closed
You have a bad door switch that has malfunctioned.
Apr 11, 2012 | KitchenAid KHMS2056SSS Microwave Oven
Our 2007 kitchenaid microwave, 1200 watts unit suddenly stopped working - it powers on as normal, but is not warming items as it should. Not sure what to do. Seems too new to kick the budket at this...
your wires going to the magnatron have probably have got loose and do not have a good connection, this is what I find on whirlpool/Kitchenaid microwaves
Feb 23, 2011 | KitchenAid Microwave Ovens
Microwave will appear to lose power (display goes dark; internal light goes dark) intermittently and inconsistently upon opening the door. Seems to be especially likely when oven has not been touched for a...
You probably have a bad connection either on the control circuit board (which we repair), the line filter board, or one of the thermostats.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Nov 20, 2010 | KitchenAid KHMS2056SSS Microwave Oven
Kitchenaids microwave error message F2.Q1. What to
F2.Q1 Not reading keypad
inputs
1. Unplug microwave oven or disconnect power.
2. Replace the user interface board (UIB).
3. Replace the door control assembly.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
Many of the error codes may be solved by power cycling: unplug microwave oven or
disconnect power. After one minute, plug in microwave oven or reconnect power.
i found this info on a tech sheet hope this helps, let me know how it goes... some of those electronics had 5 year parts warranty i would check that out....Also u might be better of buying a new one if its out of warranrty as some of those boards are expensive, obvioulsy unplug unit first try to reset it self.
Feb 14, 2010 | KitchenAid KHMS2050SSS Microwave Oven
Microwave no power
How can you take the fuse out on this model KHMS 155LSS-4 of kitchenaid
Jan 06, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! dlhamilton@comcast.net
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KHHS179LSS Convection / Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
