Magic chief washer fills with water but want wash
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
Cold water won"t fill
check the filter... make sure the line is not kinked...
Aug 08, 2012 | Magic Chef CAV2000 Top Load Washer
Water just drains, wont fill up washer
the top of the hose must be higher than the water level in the washer for proper operation
or
the drain house should be loose yet fit securely. do not seal the drain hose with tape the hoese needs and air gap
Apr 17, 2009 | Washing Machines
Water problem
Apr 01, 2009 | Washing Machines
Little water in Frigidaire front load washer
If the machine does not fill properly, it is usually because of a defective water level switch. This is also the cause for smelly clothes.
See also : It's underfilling
You can find replacement parts here.
or here Find Parts .
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Water does not fill
be sure drain hose is not too tight in standpipe ..ck to see how far down standpipe hose is needs to be no more than 6-8 ins standpipe needs to be as high as washer edge from floor..you may have siphoning problem these should correct that
Aug 10, 2008 | Magic Chef CAV2000 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
Cav4000aww magic chief washer
water is bypassing through the water inlet valve
easy fix go to lowes ect and get a cap plug for a water hose male end and screw it onto the water valve that has no hose connected to it
you could also screw on a water hose sprayer onto the valve if you have one on the end of the garden hose just make sure that it is turmed off
May 17, 2008 | Magic Chef Washing Machines
Washing Machines Logo
Top Washing Machines Experts
