Question about Delstar DS 31024 MP3 Player
Can't play all music, only plays one folder at a time
I can't play all the music on my player. I can only choose one folder at a time. How do I play all the music (randomly)?
Thanks,
Brian
    Problem Solver:
  • 6 Answers
Should have a setting under main menu that says play all try that
Posted on Mar 12, 2009
Every program opens with iTune Music Playe
Tell me about it if you have VLC installed or Windows media player you can go to your music folder right click the song you want to play and then you can select what programme to open it up with
Example I want to listen to Lordi i go Right Click then to Open With i can see the players compatible with it so i Click VLC Player and it plays through that now if you want to constantly use media player or something else you can go to Right click Music File, go to Open With then click Choose Programme Click which Player you want to use then there should be a check box saying make it your default setting after you have done this every time you click any music it will use the setting you chose. I hope this helps if it has please leave feed back or rate Kronoguy
Aug 03, 2011 | Apple iTunes 25 Music Card MP3 Player
Im trying to see all my music files on windows media player from my sansa e280 device but its only showing the ones I already have on windows media player. I do I see the other files?
connect it to the computer ..and after that open my computer folder and you willfind it like a drive ..(probably named removable disk ..or removable storage device ..) when you open that folder you will have all the music stored in there ..like in a regular folder..you can also add or remove files by copy them and paste into or delete from ..
if you want them to be played into windows media player ..just see the task aside (left ) called play all...and they will be added to the windows media player play-list ..
or ..go back ..to the drive icon into my computer ..and right click on it ..and choose play with...and select the player you want..
Aug 27, 2010 | SanDisk Sansa E280 MP3 Player
How do I set it to play random songs?
While a file is playing you can enter the Music Submenu by pressing the “M” button briefly. The Music Submenu allows you to adjust your repeat mode, amongst other things.
The Repeat Menu allows you to set your repeat mode. Choose from Normal, Repeat One, Folder, Repeat folder, Repeat all, Random, and Intro.
Choose Random.
Here is an online version of the manual, incase you have any other problems you want to read about. http://www.eclipsemp3.com/CLD2manual.pdf
Feb 27, 2010 | Eclipse CLD2 MP3 Player
Cant play folders i sent to my netbook on windows media player
hi there, for take musik from cd´s you need a "cd ripper". A cd ripper you can get here: (star burn)
http://www.rocketdivision.com/starburn.html
for ripping the music, choose "Grab Audio"
Hope that helps
IF NOT then return here
Have a nice time over there
Please rate my answer
Nov 07, 2009 | Microsoft Windows Media Player
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
Having problem syncrinizing music to mp3 player
if u used window media player its will mess up your mp3 by duplicating songs and not leting u play songs. What i do is connect it to the computer and it should pop up. DONT open window media player. Open the files and add your music by dragging them into your mp3 from another folder. This only works if you have a different folder of music. It should work. If all your music is in Widows media player it wont work. Also try deleting all your music from ur mp3 but copy your musice onto your computer first. Good luck i hope i helped.
Apr 08, 2009 | Philips GOGEAR SA6045 MP3 Player
LG shine KE970 MP3 player wont play music from memory card
yes you can, just put the mp3 file on folder "Sound" on the external memory, it will be automaticly put  in your playlist mp3 player.
Feb 23, 2009 | LG Shine KE970 Cellular Phone
Set the Delstar to Randomly play songs
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
Apr 29, 2008 | Delstar DS-3512 MP3 Player
Wharfedale mp3 SLM01 player
have charged as told through my lap top but when i go to put songs onto mp3 player nothing happens. have wharfedale SLMO1
Jan 27, 2008 | Wharfedale DVD-M3 DVD Player
Delstar DS 31024 MP3 Player Logo
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
