Question about Bell Sports Lumina LED Bicycle Light Set
How to open light - Bell Sports Lumina LED Bicycle Light Set
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
I want to van camp in my Transit 2014 - with the doors open -
Hi Jene, there should be a 3 way switch above the rear view mirror to control the lights. The 3 positions are 1.all the way over to one side = Off, 2 in the centre position = Door Open & 3. all the way over to the other side = Always On. There may be a similar switch at the centre dome light. Also have you waited for the light to go out? sometimes these lights are on a time delay.
Trust this helps, regards Alan
Apr 12, 2015 | 2014 Ford Transit Connect
When I open my garage door no lights come on. I changed out both lights with new bulbs, still no lights when I open or by manually clicking the Lights on the wall opener
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
Feb 21, 2015 | liftmaster Garage Door 1/2 Hp
Craftsman 315 MHz 1/2 hp garage door opener - when it's open the light keep turning on when somebody passes by?
This behavior is a feature of the Security+ door openers. It can be disabled via the control console:
Lights will also turn on when
someone walks through the open garage door. With a
Premium Control Console, this feature may be turned off
as follows: With the opener lights off, press and hold the
light button for 10 seconds, until the light goes on, then
off again. To restore this feature, start with the opener
lights on, then press and hold the light button for 10
seconds until the light goes off, then on again.
Those are instructions from page 30 of the manual of a similar, if not the same, opener:
http://www.searspartsdirect.com/partsdirect/user-manuals/137707/13953985DM-Craftsman-Parts-GARAGE+DOOR+OPENER-manual?pathRender=fromManualTabPage
Apr 29, 2014 | managemylife.com
I have a 2002 nissan sentra se r spec v and the dome light does not turn on when u open the doors but I does when u switch to on mode help please
dome light switches normally 3 position switches 1 position is light on door open 2 position is no light door open and no light in car 3 position is light on in car but not with door open.
Jun 01, 2013 | Cars & Trucks
Fiat doblo door open light stays on and doors won't lock
this is the door open light indicator on your instrument panel correct? it thinks the door is open. do interior courtesy lights work? i.e. turn on off when opening doors? check for "normally open" circuit faults in the door switches
Aug 27, 2012 | Fiat Doblo Cars & Trucks
Overhead light stays on all the time on craftsman garage door opener
Hello. If the light stays on all the time check these:
A. The light time delay on the opener will keep the light on for approximately 4-1/2 minutes after the system has be activated, then will turn the light off automatically.
B. If the opener has a worklight switch (which is supplied only with a four-function wall console), slide the switch to "OFF" position.
C. If the opener has a pedestrian switch (which is supplied only with a four-function wall console), the light will stay on for 4-1/2 minutes after the pedestrian door has been opened.
Mar 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Interior lights won't turn on when door opens
you have a bad drivers door latch, the micro switch inside is not telling the computer that the latch has been opened which would normally mean the door is open.
Mar 31, 2009 | 2000 Volkswagen Jetta TDI
Craftsman Garage Door Opener
From the manual:
Security+Light Feature: Lights will also turn on when someone walks through the open garage door. With a Premium Control Console, this feature may be turned off as follows: With the opener lights off, press and hold the light button for 10 seconds, until the light goes on and off again. To restore this feature, start with the opener lights on, then press and hold the light button for 10 seconds until the light goes off, then on again.
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Bell Sports Lumina LED Bicycle Light Set Logo
Top Bell Electronics - Others Experts
Are you a Bell Electronics - Other Expert? Answer questions, earn points and help others
