Question about Craftsman 675 Series 190cc 22" Briggs Stratton Rear Bag Front Propelled Lawn Mower ()
Craftsman mower pull cord stuck
Pull card stuck
4 Suggested Answers
Edvais
  • 6 Answers
SOURCE: my pull cord on my craftsman mower broke and I
With all the side screws removed it should come right off. There will be a little resistance, but that's normal.
Posted on Oct 01, 2009
SOURCE: old craftsman pull cord
Your carbs main jet is blocked most likely.
Take the carb bowl off and look at the bolt near the top of the threads.
You should see a very very small hole. If you can see through it you need to clean it with a fine strand of metal wire.
Also work the float up and down to make sure it isnt stuck or unable to flow when the float hangs free.
Put it back together and try it out!
Good luck and be careful!
Posted on Aug 03, 2010
  • 3 Answers
SOURCE: How can I get my pull cord to retract on Craftsman
HORSE POWER NOT STARED
Posted on Jul 10, 2011
Pull cord stuck on lawn mower
Pull cord stuck on lawn mower YouTube
https://www.youtube.com/results?search_query=Pull+cord+stuck+on+lawn+mower
Sep 06, 2014 | Toro Garden
What to do when craftsman mower pull cord won't recoil?
Sounds like the spring inside the recoil has either broken or let go so it won't recoil. If you are lucky it could be the wheel that the cord goes on is seized or stuck. You can take the recoil off most mowers by taking out two or three screws and lifting it off the engine. They can be repaired but it takes time having to be careful the spring won't spin and hurt you. I have even taken a recoil off another engine and if the holes for the little screws don't line up just drill little holes beside the old ones and reinstall the little screws.
I even used a 18 volt cordless drill to crank the engine using the bolt on the fly wheel and the right size socket. Leaving the recoil off You have an electric start that way.
Aug 30, 2014 | Craftsman 21" 190cc Rear Bag High Wheel...
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
Pull cord hard to pull since I hit tree root
see if the blade is bent the check the key under the flywheel
Aug 12, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My Craftsman lawn mower starter cord doesn't retract after mower starts.
I have had this situation before on a lawnmower. I didn't have a craftsman, but is probably the same issue. Basically, the spring that recoils the cord back in either broke or came unwound. When the mower is not running, the cogs on the pull chord keeps the cord from coming out. When the mower is running, the spring is not wound enough to hold the chord in and thus releases or doesn't hold it in.
Try pulling the pull chord assembly off and rewind the spring.
May 05, 2011 | Craftsman Garden
How do I replace the pull cord on a craftsman 6.75 HP EZ walk?
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Oct 04, 2010 | Craftsman Garden
Replacing a pull cord on a Craftsman mower
u helped tremondous. thank you, being laid-off i need my mower
Mar 29, 2010 | Craftsman Garden
Craftsman Walk behind lawnmower how to replace the starter pull string
Remove cowling to acces pull start assembly. Have new cord on hand. Remove old cord fragments. Wind rotor 4-5 revolutions to tension spring and hold while threading new cord into slot. Knot new cord and slowly let it wind back into assembly.
Jul 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Pull cord on Sears 4.5 mower binds up
check, or have someone check the flywheel key, it is probably sheared off.
Apr 20, 2009 | Craftsman Garden
Craftsman 675 Series 190cc 22" Briggs  Stratton Rear Bag Front Propelled Lawn Mower () Logo
32 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
