In an attempt to upgrade from sdram to ddr, used Crucial Website to identify correct memory for Syntax p4vm226 motherboard, I receive errors. I have removed the 256 M Sdram before installing the DDR 512 Module from Crucial. I cannot find any settings in the BIOS or MB to change memory types.
Comments:
Aug 10, 2007
- I have been working on this since the post. I check the bios and it was already set to auto. However, not I have a bigger problem. I changed a setting (I may have set BIOS to optumium instead of default) and immediatly after I saved and the reboot occurred, the computer locked up and went dead. If I remove the power and put the startup button, and then reapply power and try to start the computer, the fans turn slightly and then stop. I assume the BIOS does not like something. I have the old sdram memory in the computer. I have been trying to clear the BIOS, but I get the same result. I have moved the jumper to 2-3 and removed the battery Help
Basic15Aug 11, 2007
- I have tried all of the suggestions. Same result with all settings. The fans start and then stop. No other power visable.
I have tried both the jumper and removal of battery over night to clear the bios. Same result. I have set the jumper to 1-2 and removed the battery over night.
I have tied to reseat sdram memory. I set the memory settings to 133 instead of 100 and used the DDR memmory. I have moved the SDRAM to the other slot.
Before the failure, I had reinstalled the SDRAM and it was working. As I stated, the failure came after I saved the BIOS. I know that the default BIOS settings(which I should have after clearing) worked, but it was slow.
The I/O Chip is VIA VT8233
Any other Ideas would be greatly appreciated. Could it be Power Supply or Mother Board?
Basic15Aug 11, 2007
- I have ordered a power supply, and I will advise after I have installed it.
If anyone else has any ideas, I still would like any advise. I do not understand why the fans (both) start to turn slightly.Aug 12, 2007
- You are correct on what memory has to be removed. My original problem was that the new memory caused the video to go haywire. I was advised to check the BIOS settings. Now the computer will not start and I have tried everything that I can find to clear the BIOS using the old SDRAM memory. The fans move slightly when Powered UP, but that is all the power that is seen. I am now advised to replace the power supply. I normally see only good or dead power supplies, so I do not understand the slight fan movement.
I have ordered the power supply.Aug 13, 2007
- Benimur
Thanks for the great post. Let me make sure that I understand. I know that mistakes can be a real problem!
Try a new Power Supply first (I have one on order).
Then following point 4. above, remove the IDE cables, Modem, and memory. The video and sound are integrated into the MB. I also assume that I should remove all plugs from back (monitor, keyboard, and Mouse). Should I remove the power leads from the drives?
I also assume that I donot remove the Processor in any of the steps that you outlined.
Thanks again
Basic15
