Question about Brookstone Wireless Optical Mouse (400004965624)
Mac drivers for brookstone scanner mouse - Brookstone Wireless Optical Mouse (400004965624)
I can not get the Brookstone scanner mouse to install on a Windows 7 Professional Laptop?
Make sure you install with administrator privileges (right click run as administrator)
http://www.brookstone.com/webassets/downloads/ScannerMouse_817873/windows-driver_817873p.exe
why not disconnect the mouse and use the trackpad/buttons until it asks you to connect it?
Nov 13, 2014 | Brookstone Scanner Mouse
I have a brookstone photo scanner can't install on my macbook air because there is no disc drive
Open PREVIEW (in applications) and from the "FILE" menu select "IMPORT FROM SCANNER" see if your scanner appears in the list. If not, try to add the new scanner in your SYSTEM PREFERENCES PRINTERS & SCANNERS by clicking the PLUS below the printer and scanners list. It should see your scanner as long as it is plugged in and powered up. Use the drivers available such as "Generic Scanner". Once added, go to the PREVIEW application once again and try to import from scanner. PREVIEW has it's own scanning tools and as long as it can see your scanner it should be able to run it even without your software. If all else fails go online and see if you can download the scanner software from the manufacturer's website.
Feb 27, 2014 | Computers & Internet
Brookstone Scanner Mouse needs 128 mb video memory; where do I find that on my computer?
It's refering to Video Memory/Ram/Shared Memory, not your 130GB Storage Space. That would depend on the Graphics and Ram you have and how much memory is Shared. Perhaps this will help: http://www.brookstone.com/webassets/pdf/817873p_manual.pdf
Dec 01, 2012 | Computers & Internet
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Dec 31, 2010 | Office Equipment & Supplies
I purchased this Iconvert scanner today, I have a Mac & don't seem to be able to get it to install. The disk that was included with it must be only for Windows because it is useless. I have called...
I only found a couple of iConvert scanners listed from Brookstone. One is a standalone photo/negative scanner that doesn't need a computer, so I assume it isn't your model. The other one claims it will work with Mac OS X 10.4 and up, but only on Macs with Intel processors. According to the manual, the CD contains the required software for the Mac, and it should run automatically. If it's not working with your Mac, you may have a PowerPC machine and you're probably out of luck. If this is what's happening, you should return the scanner for a refund and look for one that specifically lists compatibility with PPC Macs.
Nov 23, 2010 | Ambir Technology DocketPort 485
How do I hook the wireless mouse
2 AAA batteries go into the Mouse itself.
You plug in the USB transmitter into any USB port (Windows will recognize the install the proper drivers for you automatically).
The Mouse should have a SYNC button (push that button after you add the 2 AAA batteries and have plugged the USB transmitter into a USB port).
Dec 05, 2009 | Brookstone Wireless Optical Mouse...
CRS Photo Scanner Drivers
I have just had the same problem. Have you found any solution anywhere else?
Sep 21, 2009 | Ambir Technology DocketPort 485
Computers & Internet Logo
Top Brookstone Computers & Internet Experts
David Payne
David Payne
Are you a Brookstone Computer and Internet Expert? Answer questions, earn points and help others
