Question about John Deere Garden
John deere x320 wont start no spark - John Deere Garden
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
  • 78 Answers
SOURCE: My John Deere X320 has gas fires up, but will not
It sound like a service problem. Change fuel filter. If when you pull the line there is gas there but it goes back to the tank.ITS a vent problem. IF no change then the fuel pump could be bad or a possible pickup problem
Posted on Oct 22, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deer L110 with Kohler 17.5hp backfires wont start
This model is known for shearing the flywheel key.
Posted on Nov 14, 2009
Testimonial: "Just as you said - flywheel key had sheard, an easy fix thanks very much."
nova2nv
  • 197 Answers
SOURCE: John deere x320 will not syart. if one coil ground
The wiring harness under the engine shroud that feeds both coils has a diode on each of the wires that connects coils.The diodes keep each coil from grounding each other out so when one diode goes bad it will only run on the cylinder with the strongest coil.Order new harness from Deere,cost less than $30.
Posted on Dec 23, 2009
How to adjust parking brake on the John Deere X320 lawn tractor mower?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Jul 21, 2015 | John Deere Garden
John deere lawn mower x320 22hp engine hunts at all speeds
clean the Carburetor.. This new gas is very bad for carbureted machinary.
Sep 11, 2012 | John Deere Garden
Jd X320 will not start changed fuel filte,spark plugs,and checked air filter
I assume it cranks, but won't fire up? Make sure the choke lever is moving the linkage in front of the carb. If so, tap the carb bowl lightly with a wrench. (That fixed mine once, and it never did it again) Have you had your valve lash adjusted? Be sure the carb is getting fuel. Pull the fuel line off the carb, and try to crank it... My X320 has 1,500hrs on it, and I have had great luck! Keep me posted, I want to help you get this figured out!
Oct 06, 2011 | John Deere Garden
John deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Oct 13, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John deere x320 will not syart. if one coil ground is disconnected it will start right up. if started this wsy the pto will not engaage.
Jul 02, 2009 | John Deere 3010,3020 Tractor Basic...
I need a john deere X360 44" front blade
you can buy it on ebay right now!
here's the link: http://cgi.ebay.com/John-Deere-44-Blade-X300-X304-X320-X324-X340-Ops-Manual_W0QQitemZ120402528023QQcmdZViewItemQQimsxZ20090406?IMSfp=TL090406151008r17840
May 10, 2009 | Garden
Garden Logo
195 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
