Question about Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System
Kenmore Icemaker does not usually cycle into dump position.
It will cycle a dump sometimes, but does not most of the time. Usually have to manually cycle the dump by flipping the metal bail on the side down all the way against the plastic body. Fills with water fine after a dump, but usually, after filling, it does not trip the metal bail on the side down far enough like it should so that it will trigger the next dump cycle.
It's a Kenmore Mod. 106.77992791 refrigerator. Serial EH 2513967. MFG. 6-'98.
The Ice maker is an IM #S 106 626636. LR 5010. MFG 5-12-'98.
  • 1314 Answers
SOURCE: ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
Posted on May 13, 2008
  • 149 Answers
SOURCE: Ice maker water tube keeps freezing
u can replace the plAstic one with a copper one
Posted on Oct 27, 2008
  • 19396 Answers
SOURCE: Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
  • 30 Answers
SOURCE: My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Posted on Sep 05, 2009
  • 1304 Answers
SOURCE: Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Posted on Oct 06, 2009
Kenmore 795 elite icemaker non functional. Old icemaker would not manual cycle. Installed new icemaker, still does not work. Water works in dispenser. Auger motor works. Is there a fuse link?
You failed to give a model# so I can refer to what refrigerator you have.
Some will have a green light on it,some will not. Some have an on/off switch, some do not.. And some need to be turned on from the controls/user interface.
There is usually a fusible link wired in with the heater but it would have to stay open in order to trip it so I doubt this is your issue.
First, I would see how to turn it on. (Most side by sides have a rocker switch on the icemaker and typically have a green light.. Top freezer's are usually the same. Bottom freezer's with the icemaker in the freezer usually have no light on the icemaker but do have a rocker switch ((( Note *** Some, but not many are wired through the light switch so trying to cycle with the door open will not work.. You need to close the light switch either mechanically or with a magnet if it a magnetic switch)))... Bottom freezer French doors can have an on/off switch,typically no green light,or no on/off switch and needs to be turned on by the controls.
Pleas give more info if you need more help as there are probably 1000 variations of a 795 elite refrigerator as it has been produced for roughly 14 years now.
Jan 29, 2018 | Kenmore Refrigerators
Ice maker leaves 2 to three cubes on most dumps. then it stops dumping until they are removed
Check the the part called the cube rake. Its usually a white plastic piece with fingers that point to each cube mold. Its suppose to push the cubes out during the cube dump cycle. It sounds like a few of the fingers may be broken and not turning properly on the shaft to extract the cubes out of the icemaker. The rake should push the cubes out during the cycle.
May 15, 2015 | Refrigerators
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
It making a load buzzing nosie hafe way threw the cycles and it stops and my clothes are not rasied out and soaked still from not being spinned i dint put no more then usually iv had this probmle before...
F30 Dispenser system error . Bad or jammed motor, broken wire.
Remove the dispenser and put it in the dishwasher for a cycle. That will clean it up.
Take the bottom panel off and dump the pump filter.5cfa9a5.jpg0084008.jpg4d0f9ba.jpg
I have a service manual HERE with more info
Oct 19, 2010 | Kenmore HE2 Plus Front Load Washer
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cubes form a mass that do not dispense
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 11, 2009 | Kenmore Refrigerators
Icemaker will not dump ice into bucket
Unfortunately your icemaker is showing classic signs of failure and it is time to replace it. You will need to go to and go the the parts tab. You will need the actual number off of the refrigerator tag. It usually has three numbers, a period and then 6 to 9 more numbers. Once there you will be able to locate and purchase the icemaker you need. It is a simple replacement and will work like a champ when you are done.
Jul 16, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
Will not dump tray...stops at 2:00 position, will not advance
Possible cause of this is. 1st the heater is out. 2nd the motor in the icemaker has a dead spot. If heater then the complete icemaker should be replaced. If motor I would replace the faceplate.Part #150 Should be around $55 for part. You can find parts by visiting u-line at and under customer service you will see parts locator.
Jun 08, 2009 | U-Line Icemaker
Ice maker leaking water
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Model 95 Icemaker no ice
The cycle starts when you turn the icemaker on. It starts the dump cycle when the compressor turns off. The mold heater turns on and the cycle motor stalls until the ice cubes release and lets the moror complete its cycle. Then the compressor starts to repeat the cycle. If the mold heater is bad (it should read about 80-85 ohms) it will not dump all the ice and the mold will overflow on the next fill part of the cycle. If the over temperature switch is bad (checks open) It will not let the mold heaters work. The over temperature switch should NEVER open. If it IS open the mold heaters will not heat. MDB
Dec 04, 2007 | U-Line Icemaker
Kenmore 21.7 cu. ft. Top Freezer Refrigerator with Acceler-Ice 3xi Ice System Logo
443 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
