Question about Goldstar Microwave Ovens
Gold star microwave mv1608ww - Goldstar Microwave Ovens
MicrowaveSvc
  • 9085 Answers
SOURCE: need help with my Gold Star microwave.
The owner's manual won;t tell you that, only the repair or service manual.
While we don't have that exact model, we do have the manual for a similar model uploaded here.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Goldstar owner's manuals can be downloaded here.
Posted on Aug 10, 2008
  • 3 Answers
i just took out my fuse on the same model. you have to pull down the microwave and take cover off. there should be like 6 screws on backside and cover will slide back and off. then you will see a fuse cover with a small cylinder fuse in a plastic cover. pull it out and check continuity with volt meter. mine unfortunately came up good still, so i dont know what kinda problem mine is having. had a short in light and it popped and power was gone. good luck!!
Posted on Apr 07, 2009
kevin_max
  • 37 Answers
SOURCE: my gold star microwave worked lastnight. Went to
The outside bottom of your microwave usually has a belt hidden underneath a small cover directly under the turntable. This belt sometimes falls off or breaks, and sometimes the motor that turns the belt fails. Most time the motor can be found if you remove the main top cover of the microwave, about 10 screws.
Parts can be easily found at your local appliance parts store.
Best of luck.
Posted on Jan 21, 2010
bestdarngood
  • 3037 Answers
SOURCE: Gold Star 1515W microwave not heating up and when
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Posted on Jul 20, 2010
marc_uhrey
  • 72 Answers
SOURCE: the power in our MV1608WW
Most microwave ovens have a fuse. It may be a cartridge-type. You will need to remove the fuse from its socket and use an ohmmeter to check fuse continuity (that current can pass through it). If the reading is very high (kilo-ohms or mega-ohms), the fuse has blown and will need to be replaced.
Be SURE the microwave is unplugged before doing any testing!!!
Posted on Mar 13, 2011
Testimonial: "thanks a bunch!"
Ineed a manual for a MV1608WW
http://www.searspartsdirect.com/partsdirect/part-model/Goldstar-Parts/Microwave-Parts/user-manuals/manual-downloads/Model-MV1608WW/1366/0123370?modelNumber=MV1608WW&diagramPageId=&documentId=
Sep 04, 2013 | Goldstar MV1608WW 1.6 cu.ft. Over The...
My Goldstar MV1608 stopped rotating and heating food yesterday. All other functions seem to be operating such as the light, fan, panel, etc. It is 18 months old. How can I fix it?
If there is no heating it is possible that the MAGNETRON has failed provided there is supply feed to the unit when the microwave is powered. Normally the magnetron along with the fan and light comes on when the microwave power is triggered. So since the rotation is absent it is possible that there is no power feed from the processor board which can be related to a driver failure. You need to check the output from the PROCESSOR to confirm and pinpoint the defective component. Check the relay to the magnetron trigger as this can be a suspect.
Oct 24, 2011 | LG MV1608WW Microwave Ovens
The power in our MV1608WW by gold star (LG) just cut out. how do we replace the internal power supply?
Mar 13, 2011 | Microwave Ovens
A Gold Star model MV1610WW microwave over stove will not heat anything. The table turns but will not cook.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 25, 2010 | Microwave Ovens
Benjamin
Jul 17, 2010 | Goldstar MV-1515 Microwave Oven
My Gold Star Microwave Oven MV1610WW Stopped Heating. It turns on but does not cook.
Basic Microwave Oven TroubleshootingTips
heatman101[p]]][p
May 31, 2010 | Goldstar MV-1526 Microwave Oven
My gold star microwave worked lastnight. Went to
Best of luck.
Jan 20, 2010 | Goldstar Microwave Ovens
Need help with my Gold Star microwave.
Mar 08, 2009 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
