Question about HP Deskjet D4260 Printer
I cannot print with my HP color ink jet printer cp 1700. Initially there was a paper jam in the printhead area to the right of the printer. Now the printer just continues to run and states to close the latch of the print heads. This appears to be latched and secured. There is a ribbon that is visable inside when you open up the top and the carraige doesn't automatically go back to the original position to the right. What should I do?
  • Lora Quirk Mar 12, 2009
    The motor on the printer is continuously running. There is a ribbon that runs through the printhead housing that is not attached anywhere.
    What 4 screws?
  • 564 Answers
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=110&prodTypeId=18972&prodSeriesId=33103
Click on the Troubleshooting Links and Follow the steps.
Hope this Helps!!! Thanks!!! PREM
Posted on Mar 12, 2009
    Brigadier General:
  • HP Master
  • 3,614 Answers
initially, let the printer rest for an an hour, unplug the printer and also resart your PC before turning it ON
    Sergeant:
  • 300 Answers
As the ribbon should automatically back but its not going so just get it repaired.the ribbon needs replacement .it will cost you $5 for new ribbon and plus the service charge of the engineer.its worth getting it fixed.get it replaced,the printer oy yours have a good life so get it repaired.
  • 10,515 Answers
    Sergeant:
  • 320 Answers
That ribbon needs to be resetted by opening the four simple screws of the printer.its very simple to refit the ribbon.
    Brigadier General:
  • 8,619 Answers
Hi!
Check out for small pieces of paper stuck under the carriage. Also use a Q-tip and apply a drop of oil on to the crome rod on which the carriage rests
My printer shows a code#3527 and states a problem with the printhead..i show nothing wrong what is the error ?
This one pops up a lot when the printhead sensor gets dirty. I would pull the paper out, give the inside a good blast of canned air, pull the cartridges and then reload it like you're setting it up again the first time: paper, ink, test print. If you still get the error code try cleaning it again but on its side or back and check the print head belt and rail, too.
Mar 03, 2015 | Kodak EASYSHARE 5300 All-In-One InkJet...
My HP color Laser Jet 2600 printer has a paper jam
Jul 21, 2014 | HP Office Equipment & Supplies
Hp inkjet 1700 primthead locked
I Suggest You To Watch Cleaning the Printhead Contacts To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On :
HP Printer Support
Apr 19, 2013 | HP Color Inkjet CP 1700 Ink Black Replac -...
When printing in color the right edge of paper is smuged
Inks from your printhead is deposited on right side of the soft sponge across the printhead pathway. Take a tissue paper and fold it and gently dap it dry
Nov 01, 2012 | HP PSC 1600 InkJet Printer
Yellow printhead on my Designjet 3500CP isn't releasing ink
If you can access the printhead, try taking a rag with a small area heavily wet with Denatured Alcohol (this is a cleaning solution that can be purchased at Walmart or most stores with cleaning supplies. Rub the printhead thoroughly with the alcohol for a minute or two, it should help loosen any dried ink. Then try to print or run a print head clean cycle on the printer.
Nov 03, 2017 | HP Designjet CP UV Yellow Ink System...
My HP Office jet 6210
If the printer seems to be printing and ejects paper when a page seems finished, communication is happening, just no ink.
To see if it is an ink or printhead problem, take any Word document, highlight all text and change the font color. Then try printing it; I would try this with a few different colors to see if any part of the printhead is capable of producing visible material.
Oct 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
5300 kodak eazyshare printer
Well, here is the proper way of fixing or troubleshooting that paper jam error in your printer
Open the printer access door and remove both of the ink cartridge, then remove also the printhead, after that close the printer access door, without those parts. Then it will show a message in the printer screen, "Printhead is missing or has come loose" or "Printhead Not Detected" Install the printhead, just the printhead without the ink cartridges. After that close the printer access door. Then it will show you a message"Ink cartridges is not installed,install ink cartridges". then open again the printer access door, then install the black ink cartridge without the color ink cartridge. then close the printer access door, then message must be " Color ink cartridge is not installed, install color ink cartridge" then install the color ink cartridge." the message must be,"New printhead is detected calibration require, load paper and press start"
Thats the way of overiding the paper jam error message of your kodak all in one printer
hope this will help you guys
by: E.brown
Happy Printing(", )
Kodak AIO tech support 1-800-421-6699
Jun 04, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Aug 14, 2007 | HP PSC 1215 All-In-One InkJet Printer
Lexmark 5400 series printer
Just today, our Lexmark 5400 began having paper jam issues. We'd try to print, and the paper would initially feed into the back and then wouldn't go any further. Then it gave printer jam error messages. After peering and poking into various areas of the unit I wound up disconnecting the printer from power, phone line, and USB connection, I took it to a better lit room.
Peering carefully into the back paper feed area, I discovered a pencil!! After excising the pencil, the printer worked fine. One of my precious children must have accidentally dropped a pencil into the back, or a pencil was resting on top of the unit and rolled into the back paper feed area.
Lesson learned, don't put pens or pencils on top of the printer.
Jul 09, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP Deskjet D4260 Printer Logo
Seeker5211
Seeker5211
