Question about Acer Aspire One PC Notebook
I have the Blue Screen of Death
The computer loads up and ask if i would like to start windows normally or safe mode, either one that i hate brings up the window as if windows is about to start up but right before that the blue screen flashes and i cant get the code for the problem. And then the process just repeats.
  • thileep Mar 12, 2009
    same as kenny's problem. but I'm using Vista Home.
    How can I reinstall the vista ? somebody help me..
  • 94 Answers
You need to reformat your laptop and install fresh copy of operating system all you need is windows xp cd or vista cd
Posted on Mar 12, 2009
Blue screen when windows loading screen
There's a number of reasons that you could have that issue. HDD failure, RAM failure, some sort of Windows driver issue.
Try restarting the computer and before the Windows loading screen, start mashing the F8 key. That should bring you to a screen that offers to start you in safe mode. Try starting in safe mode, which only loads the absolutely necessary files for Windows to load, and see if it'll start up there. If it does, attempt to use Windows Recovery Tool.
Mar 03, 2015 | Acer Aspire Computers & Internet
Blue screen of death. how can i ifix>? running windows 7 ultimate 64 bit
First try to start the computer in safe mode.
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | MSI P55-CD53 (4719072129125) Motherboard
Blue screen of death. unable to download drivers. can not get to safe mode. cannot reload orperating system disks.
First off, note down all relevant information when you see a BSOD flash across the screen. This includes the error number and friendly name from the 'bugcheck' section of the stop error (see above), and any file names specified in the 'driver information' section.
If the BSOD comes up on the screen for a split-second before the PC restarts and wipes all the useful information away, we need to change some settings within WinXP. In most cases, it should be possible to stop your PC from automatically restarting when it develops a major error, allowing you enough time to jot down the BSOD error message. If you are using WindowsXP, right click on my computer > Properties > Select the 'Advanced' tab > and under 'startup and recovery' click the 'settings' button. This will open a new window, and under the 'System Failure' heading, uncheck 'Automatically restart.' Continuing on, attempt to restart the computer normally into Windows. If the BSOD occurred while booting Windows, you may be taken to a troubleshooting menu and will have to select 'attempt to start Windows normally.' If your computer starts correctly, continue using it and store the error information for later reference. If the BSOD reoccurs at random or irregular periods, see Section D below on troubleshooting intermittent stop errors.
If your system does not start correctly or the stop message happens again, reboot the system. When the POST (memory checking) screen comes up, press F8 repeatedly. This will bring you to the Windows advanced options menu.
In the Windows advanced options menu choose 'safe mode' to attempt to boot into Windows Safe mode. Safe mode loads Windows XP with a minimal set of drivers and no automatically loaded software. If faulty software or drivers are causing your BSOD problem, safe mode should load correctly. If safe mode loads correctly, refer to Section A below on 'troubleshooting software stop messages.'
If safe mode does not load correctly, and/or you get the same stop message upon attempting safe mode, it's time to try the 'restore last known good configuration' option in the advanced options menu.
Restart your computer, pressing 'F8' again to load the advanced options menu and select 'last known good configuration (your most recent settings that worked).' This uses Windows XP's built in system restore utility to restore the most recent save point, which should be the last time you installed any drivers or other software. If your system boots normally after this operation, hopefully your problem has been fixed.
If you are still receiving a Blue Screen Of Death after the above procedures, or if system restore was disabled on your system, note down any new information on the error and start thinking. Did you install any new hardware or software just before this problem occurred? The driver information section of the BSOD may help with this.
If you did install new hardware or software, and you think you know what it might be that is causing the problem, this gives you a big boost in resolving the situation.
Otherwise, proceed to the advanced troubleshooting sections below. Chances are your error is hardware or system file based and will require more effort to repair.
Specific Repair Instructions
If you have a reoccurring Blue Screen Of Death or crashing problem, and can't use Windows effectively because of it, it's time to look at more specific methods of troubleshooting your problem. Depending on the results of the basic troubleshooting steps above, you should have a good idea of whether the problem that is causing the stop messages is related to software or drivers you have installed, or is a hardware or system file issue.
Essentially, if you can't boot into Windows XP safe mode because of crashes or Blue Screens Of Death, you likely either have a hardware error or one or more essential system files is corrupted or missing. If you can boot into Windows XP safe mode, but get constant or frequent BSOD's when running XP normally, you have a software or device driver problem.
Make sure that if you added any RAM to your computer which is a common cause for BSOD that you added the correct RAM for your computer and that it is equally distributed in the ports meaning each port for the RAM has the equal amount of RAM on each side (eg, one stick 1GB, and the other has 1GB, etc).
Jan 03, 2010 | Dell Dimension 2400 PC Desktop
PC monitor has blue USER MODE box that flashes and cannot get rid of it
The blue screen of death is incredibly frustrating. Windowsmag-glass_10x10.gif gives you an option called Safe Mode for whenever there is an internal Windows problem on your PC that needs to be resolved such as the blue screen of death or the display driver setting resolution is so low that you cannot navigate through Windows to alter the settings to a higher resolution. Safe mode allows the user to fix problems without these problems loading up.
  1. tep 1 Reboot your PC. If you can't restart normally by going to the start up menu, then hold in the power button for a few minutes. If you need to enter safe mode but can restart normally, do so.
  2. Step 2 After the hard drivemag-glass_10x10.gif mounts but BEFORE Windows starts to load, Press the F8 key repeatedly on your keyboard. If you do not get the menu with the safe mode option, then you did not begin tapping F8 soon enough. Try again.
  3. Step 3 There will be a menu that will appear. Select Safe Mode. Once you are in safe mode, you can fix what needs to be fixed without the problems loading up on your machine.
Nov 13, 2009 | LG Flatron L1715S 17" LCD Monitor
When it turns on all i get is a blue screen. It is a brand new computer. How can i fix this problem?
Ah the dreaded Blue screen of death. sounds like windows as gone down. try Alt F9 this may bring windows up temporaryly, or hold alt F9 when the computer starts to bring up safe mode, then working in safe mode see what has changed on the system
Jul 12, 2009 | HP Computers & Internet
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Nov 13, 2008 | Compaq Computers & Internet
Can't get to login window
Blue screens are normally critical errors. If you have loaded any new hardware to your computer lately or some software packages you will need to uninstall them.
Try starting windows in safe mode by pressing F8 continuoulsy until you hear a beep. This will start the computer in safe mode and everything will look big on the screen, ignore that for now. While you are in safe mode uninstall anything that you have loaded prior to this error. Be it software or hardware.
If you have not loaded anything recently then try restoring your computer to an earlier time when you know that it was working with now problems.
Once safe mode boots go to Start>all programs>accessories>system tools>system restore and choose a date when you know that the computer was running okay. Once the restore has taken place the computer will reboot. If asked what mode you want to start in choose start windows normally.
Hopefully this will help you resolve your problem.
Nov 11, 2008 | IBM Computers & Internet
I Keep Getting The Blue Screen Of Death
well my friend Welcome to the world of XP sucks don't it, but all is not lost! if you have your copy of windows XP re istall the software, do a fresh install, delete the old system (Partition) and start with a New (RAW) partition, and install xp as instructed in the step by step installation. you will lose all the old data on your hard drive, but the system wull have a new lease on life, don't forget the automatice updates after your back on line, and to install NEW anti Virus software, turn on your firewall, and The BLUE SCREEN OF DEATH will lose and you win.
in the future be careful what web sites you visit, stay of Lime Wire, and blubster, and chose web sites wisely, and windows defender is a great product to tell you if you have a potential dangerous web site, if your warned DON'T GO IN!
This will fix u r problem! I guarantee it!, if you need a new XP disk, let me know.
I HATE THE B.S.O.D ( Blue Screen of Death)
Jun 16, 2008 | Dell Inspiron B130 Notebook
The problem is really on your operating system. You have to reinstall the O.S. of your pc. Have your windows installer ready and repair the damaged operating system and it will go back to normal.
Dec 04, 2007 | Compaq Deskpro 2000 PC Desktop
Acer Aspire One  PC Notebook Logo
287 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
