Question about DISH Network IR Remote Control
I have an IR Remote control 103781. I want it to control a Sanyo
Title: How ti set a remote control
  • 374 Answers
Check the answer on your other post. Thanks for using Fix YA.
Posted on Mar 12, 2009
I have a Sanyo fve3963 T.V. and a Pulse IR URC2069 remote control. The only thing that the remote will do is to turn the power of the T.V. on or off. Reprogramming remote didn't help.
Some universal remote controls handle only a couple of basic functions of the device. You may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
May 22, 2017 | Sanyo Televison & Video
Can i program my general electric remote to my sanyo television
Setup codes to check with Sanyo TV with GE universal remote control are: 0049 0097 0110 0004 0268 0012 0108 0180
To get more details about the set up proceedings, click here.
Aug 25, 2012 | DISH Network IR Remote Control
EchoStar IR Remote 103781 where to purchase in Toronto, Ontario
Gordon ****,
You can definitely order a remote through an agent by calling in. To pick one up locally, I would recommend going to a authorized retailer. Use the link below to lookup local retailers in your area! If you have any other questions or need any assistance, just let me know!
Link: http://www.dish.com/support/tools-apps/locate-retailer/
Tommy Faust
DISH Social Media Representative
Aug 17, 2012 | DISH Network IR Remote Control
Yamaha stario codes for echostar tecnologies ir remote 103781
Hey Hiall Hollingsworth,
I would need the remote model to provide more specific codes, but a few for Yamaha Stereo are 663, and 733. You can view the link below to get model specific codes!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Let me know if you have any other questions!
Tommy Faust
DISH Network
Nov 19, 2011 | DISH Network IR Remote Control
DS27930 27" TV: I have a Sanyo DS27930 tv and the remote hasn't ha...
check the remote control for any rust on the contact terminals of the dry cells.If present sratch it off and place back the cells and see if it operates.if it does not work you can easily identify the between the tv or the remote what is mulfanctioning by testing the remote for ir radiation,simply by directing the remote to a camera sensor of your mobile phone,if ir light is seen as you press the buttons then the remote is good and if not then the remote is faulty and might need technical expertise to repair.however if you see the ir light ,the problem lies with our set
May 18, 2010 | Sanyo DS27930 27" TV
Want to use my remote for a Echostar 4100 on my other box which is a 3100 i have remote IR remote 103781
me1969
The remote you mentioned is not compatible between the different receivers. Some remotes can be used with different receivers. You would need a new remote if you are having problems with the other remote. I hope this helps.
Ray Calo
DISH Network
Apr 03, 2010 | DISH Network IR Remote Control
I want to use my Echostar Tech. IR remote model 103781 to operate my JVC PCX-101 portable stereo, but I have no instructions or code. Can you help? Thanks .... Doug .... dgplcy@yahoo.ca
http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/8.0.shtml This is the site that will help you with your issue.
Thanks for using Fix Ya.
Feb 12, 2010 | DISH Network IR Remote Control
What is thecode for rca tv
Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
OK first and foremost not all tvs are supported by Dish remotes. This is especially true of combo units bbut here is the easiest way to program the remote if the tv is supported:
Press and hold the clear tv button on the top of the remote until all buttons across the top light up.
Now press the smallred tv button and release it.
The top tv button should be lit constantly now.
Now press the arrow up key slowly until the set turns off.
Once it has press the arrow down button once and then the arrow up button to see if tv turns on.
If it does press the pound key and release.
The topmost tv buttton will flash three times.
You are now ready to press the SAT key on the top of the remote and watch tv as usual controllling volume etc with the remote.
If the set turns off but you can not get it to turn back on turn the set on manually and start the process again- it will not go back through the codes you already had tried.
If you notice the tv button flashing rapidly it means you are at the last code and need to go back the other direction or that there is no code for your set.
If the set turns off but will not turn back on then you have a partial code which will not perform properly. Thanks for using Fix Ya.
Mar 12, 2009 | DISH Network IR Remote Control
IR remote 103781- Looking for control code for the INSIGNA TV
If you have tried locating your tv type in the back of the manual that came with the receiver and can not locate it then chances are that the remote does not ssupport your TV. You can try finding the code by doing a power scan as follows to see if one not associated with your tv will work: With the TV on press and hold the TV button on the top left of the remote until all buttons light up across the top. Now preess the small red tv button-the topTV button on the left of the remote should stay lit. Now press the channel up button slowly until the tv shuts off. If it does press the channel down button and then the channel up button. The tv should now turn on. If it has press the pound sign and release. The tv button will flash three times. Now try powering the tv on and off. You should be sucessful. Remember to put the remote back into SATmode. Thanks for using Fix Ya. Let me know if you need further assistance.
Jan 12, 2009 | DISH Network IR Remote Control
DISH Network IR Remote Control Logo
409 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
