What can i do to get this thing to work or replace.older model printer 1020 inkjet printer. i got new used computer. gatewaycomputer.
  • shebah123 Mar 14, 2009
    will not print at all. it shows on the screen printer is not listed . it is a lexmark 1020 inkjet printer. i think it is too old and needs to be replaced....what would be a good printer..........
What is the problem with your printer
Posted on Mar 12, 2009
RESET PRINT COUNT HP 1020 PRINTER
A cold reset should not reset the print count. Those are usually stored in non-volatile memory to prevent scammers from selling used products as new.
Jan 09, 2015 | HP LaserJet 1020 Printer
There was a problem with teflon sleeve in hp 1020 printer. so i replaced new teflon sleeve. But after i replaced teflon sleeve i faced a new problem. that is, there is a noise just like a drum frictio
when replacing the Teflon sleeve did you clean the heating element? if so did you also re apply new fuser lube? this Lube is not a normal lube.. its a lube that is specifically manufactured for fuser units and Teflon sleeves.. you can buy it thru a Company called Precision Roller look them up on line
Apr 01, 2014 | HP LaserJet 1020 Printer
Please sure that when you replace teflon sleeve can you lubricate it's base with soilicon or other high quality grease..... if not then do so
other thing is that be sure about noise it is from drum or upper portion of the printer
Only print blank
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 10, 2013 | HP LaserJet 1020 Printer
Hello, I have a printer and I'm trying to install it. My printer is HP LazerJet 1020 and I used it before but for some reason I just can't print!
Hi there !
Have you installed successfully your printer software and print a test page if its working? Or was successfully install but cannot printer any thing? Are you install on directly to your computer or using a lan network? This printer can be installed easily with no problem. I believe that you had problem with the usb driver.
Jan 09, 2011 | HP LaserJet 1020 Printer
With new computer, it does not print on the fi;rst
Disconnect HP 1020 from computer. Go to "printers" in the start menu ad delete all of the installed printer drivers. Reconnect HP 1020 and have Windows re-install a print driver for teh printer.
If problem continues, do the above steps again, but before re-connecting printer, down load a driver from the hp web site and install it. Then re-connect printer and try it again.
Aug 04, 2009 | HP LaserJet 1020 Printer
Documents was not sent to HP Laserjet 1020 printer
Check connection cable first, eventually try a replacement.
Reinstalling drivers usually fix this problem.
Reinstall drivers with printer connection cable unplugger, either using driver CD or download from the link below.
HP LaserJet 1020 Printer series - Download drivers
May 21, 2009 | HP LaserJet 1020 Printer
HP LaserJet 1020 light is not on although plugged in & no print
i have a hp 1020 printer and i have change its teflon but the toner not fixrd on the paper properly.
Dec 15, 2008 | HP LaserJet 1020 Printer
Driver for 1020 hp for macintosh
copy and paste link into address bar and then put in your priner model all the software will come up. just select your operating system and download software
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
Dec 26, 2007 | HP LaserJet 1020 Printer
Computers & Internet Logo
David Payne
David Payne
