Question about Primera Technology LX810 Printer
Is it possible to cancel the warning for low ink
  • richard94607
    richard94607 Apr 21, 2013
    The printer gives the warning too early and it is a pain.
  • Primera Tech... Master
  • 7,993 Answers
Yes, you can replace the cartridge that is giving the warning. You can also ignore it. When there is no more ink the printer will stop printing or the print quality will deteriorate. Similar problem: What does one do when the fuel gauge of a car light up?
Posted on Apr 21, 2013
Flashing light occuring in triangular symbol and printer malfunctioning. Colour ink is low or possibly out and receiving message that ink absorber is full. What remedial action can I take?
First press cancel for about 5 seconds - this way you reset the ink level error. What concerns the ink absorber error, I need to know your printer model exactly .
Apr 06, 2016 | Canon Office Equipment & Supplies
How to override lexmark s415 low ink
There's no way to override the low ink warning. If one of the cartridges is out of ink, you won't be able to continue printing.
Refilled cartridges will not report or reset the ink levels.
Jan 09, 2013 | Lexmark S415 - multifunction fax / copier...
Have installed new ink cartridge. still getting low inw warning
The low ink cartridge warning is nothing to worry about. If it prints, it prints. Most modern printer cartridges have a chip on it which lets the printer know when the ink is low. When you run low on ink, it sends a message to the printer which sends a message to the computer telling you to refill the ink. The problem is that it doesn't go away once you refill the ink. It still prints, you just get a notification whenever you want to print. You can still use it up until that new cartridge runs out of ink. :)
Feb 21, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Can one reset the Lexmark P6250 printer refilled cartridge?
No, you can usually tell your printer to "ignore ink levels" when it gives the ink low warning on your computer screen. As long as they print just keep printing until they run out.
Dec 28, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Changed black ink caertridge but still getting the low ink warning
If you are using a remanufactured cartridge, the low ink warning is actually normal. Since the printer cannot detect the amount of ink in the cartridge, the OEM companies place a chip inside of each cartridge that counts the number of pages that you print. When the cartridges reach a certain number of pages, they automatically tell your printer that you are running low on ink. Unfortunately, when the cartridges are remanufactured, the chip is unable to be reset. Here is a link to a site that sells remanufactured cartridges on how to bypass the low ink warning on Lexmark printers:
http://swapink.com/Merchant5/merchant.mvc?Screen=lexinst
Nov 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
New printer. Black cartridge doesn't work. No black on test sheet
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK.
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
New black cartridge installed. Won't print. HELP please.
Try
Important
Note
Printer shows low ink but will not print at all now. it always has before with low ink.
try keeping pressed the cancel button for 6 seconds, that will disable the lower ink sensor, some times it is necessary repeat the procedure to the disable, the low ink warning must dissapear.
Jul 20, 2009 | Canon PIXMA® MP530 All-In-One Printer
How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Dec 15, 2008 | Canon PIXMA MP470 All-in-One Printer
I CHANGED MY PIXMA INK CARTRIDGE AND HOW TO RESTART?
Here's what you can do....
METHOD #1 - Easiest, but it disables the ink tank level indicators.
1) Ignore the low ink indicator, and press the RESET BUTTON to continue printing. If you press and hold the reset button for 5+ seconds, it will disable the counter for that particular ink tank. Refill tank now.
2) Repeat as needed.
You will get a dire warning that this will void you warranty, blah blah blah. If you do need to take your printer in during warranty and you've disabled ink tank counting, simple reset the entire printer as describe below for the wate tank warning, and nobody will ever know. SAVE YOUR CANON CARTS with a bit of ink left in- your printer will need to have Canon carts installed for warranty service.
3) Eventually you may be warned that the tank is empty. Press reset as above to disable and continue printing.
If you think this entire thing is ridiculous- you are right.
Get an earlier model that takes un-chip carts, like an ip6000, or ip3000, or i960. Much simpler and you get to use the ink tank indicators after refilling.
You can reset the entire printer with the WASTE TANK reset (below) when you need to clean or change the waste tank PAD (its really not a tank) See the above instructions for the i960 and similar for other Canon printer waste tank changes.
Here's the ip4200 reset options:
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power
in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Nov 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Primera Technology LX810 Printer Logo
53 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Guy Loeffler
Guy Loeffler
Level 1 Expert
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
