Question about John Deere EZtrak Z225 Zero-Turn Riding Mower
Belt on my John Deere Z225 came off and I'm having trouble getting it back on all the pulleys. Is there a trick to getting it on the last pulley?
I have the belt threaded but cannot get it on last pulley because there is too much tension in the belt.
  • 1114 Answers
SOURCE: noise, idler pully rubbing against middle blade
Unless there is some other means of placing tension on the deck belt, I would say that the idler pulley does. If the idler pulley is on a pivot arm, there is a spring that typically is attached to the pivot arm, near the pulley, that attaches to a post or some other part of the deck, that creates the tension on the belt. Check the belt for proper tension.
Posted on Aug 01, 2009
backwoodsctr
  • 169 Answers
SOURCE: The pulley to run the mower will not turn on my
99 PERCENT OF THE TIME YOU HAVE A FAILED SPINDLE BEARING CAUSING THE SPINDLE TO "LOCK UP" SPINDLES CAN BE PURCHASED ONLINE AT A FRACTION OF THE COST OF A JD DEALER....HOPE THIS HELPS GOOD LUCK
Posted on Nov 23, 2009
wireguy212
  • 1627 Answers
SOURCE: replacing drive and auger belts on a John Deere 1032 snowthrower
You don't need to remove the any lever linkages but you will need to remove some of the pulleys.If you can give an exact model number of the tractor it would help.
Posted on May 08, 2010
  • 146 Answers
SOURCE: I'm attempting to replace the primary belt on a
There is an idler pulley that puts tension on the belt. You unhook the spring from the idler arm, put the new belt on (it will be loose, not tight) then hook the spring back onto the idler by pulling hard on the spring with a pair of visegrip or channellock pliers. Here's a parts diagram. Good luck! Please rate my solution if helpful, thanks.
Posted on Aug 03, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a John Deere
I hear that on the service manual and the springs. Take a look at these decks if you talking about a deck belt and find yours. Then look for the spring routing visually.
http://opebycrigby.tripod.com/decks/jddeck.html
If you need drive belt info look here:
http://opebycrigby.tripod.com/drive/jddrive.html
I would like to know if this was enough info for you so that you were able to re-connect the spring.
Thanks for choosing FixYa,
Kelly
Posted on Jul 01, 2011
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
I need a diagram to replace belt on a 60 in deck on a John Deere 420
Make a loop with the three drive blade pulleys, the other two are tensioner pulleys, if they are flat pulleys as they should be the back side of the belt rides on these , if they have been changed then use them as tension pulleys anyway you can, hope this helps.
Sep 14, 2014 | John Deere Garden
Belt diagram john deere sabre 1338 GXABRF
the cheap john deeres are notorius for belt jump. Have to look at idler pulley while engaged in normal cutting height and see if it rides the upper edge of the idlers. I have had to bend up the idler arm so it runs a truer line into the pulley/idler so it doesnt creep over the edges.
Aug 30, 2014 | John Deere Garden
Belt slipped off Transmission Pulley of John Deere D110. How to get the belt keeper aside and put the belt back on the pulley?
There are usually two bolts securing the keeper to the bottom of the tractor. remove one and loosen the other and you should be able to swing it out of your way. worst case is to take them both out and replace the belt and reinstall the keeper
Aug 25, 2014 | John Deere Riding Lawn Mower. D110 42 in....
Trying to change the blade belt on my john deere gx75 lawn tractor and can't can someone help me through this?
Get in touch with your common sense. You have the deck out from under the mower and you have cleaned it. By chance is there a belt install guide on a sticker on the deck? This is a very common sticker. If you can get on fixya you can Google "John Deere deck belt install" with your model number. Failing all that, look at all the pulleys and the belt itself. The belt is flat on one side and v shaped on the other. Now look at all the pulleys, some have a groove and some are flat. The groove tells you the v of the belt goes in there and the flat tells you it is to take up slack or absorbs shock and the flat of the belt runs touches it. There is but one way it will go. One of the pulleys moves in an arc on a spring loaded swivel, that is your tensioner and will be the last one as you will move the tensioner to get it installed.
Aug 22, 2010 | John Deere Garden
I am looking for a belt diagram for a John Deere LH108 riding lawnmower. the belt has come off and I am having trouble getting it back on. It looks like the little black bar is next to the pulley and I...
If this is the guide your talking about: http://jdpc.deere.com/pimages/MP30/MP30295________UN14NOV02.gif
You will have to losen all of the 6 bolts to get the belt on. The belt guide is there to prevent the belt from jumping off of the pulley and it fits very close to the running belt. Without losening the bolts you will not be able to get the belt on.
Thanks for using FixYa.
Kelly
Jul 05, 2010 | Garden
Blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Jun 07, 2009 | Garden
John deere 316 belt
I am so far from expert...me answering this surprises me. However, I can...JD Small Engines has plenty of diagrams for the 316. Here's how a old single lady changes the belt on her 85 316. There is a bolt running from side to side of a black metal box...on the very front at the bottom of the mower below the grill. If you pull that out, just the front of the mower deck separates from the mower..slip the belt in and around the rear central pulley. Put the pin back in with the belt now around the back pulley and outside the part where the pin goes back in. Get a pneumatic tire jack and jack up the right (your left as you face the front of the machine) front pulley..try to catch the pulley armature or bolt so you don't torque the pulley. This releases the tensioner...thread the belt on the right pulley and reach up under the grill and put the belt over the front engine pulley....now all that's left is to get the belt over the left pulley. At this point, I remember having to either lower the deck to the ground or raise it up all the way...to the ground, I think as it wasn't already in the correct position. Once you start fussing with the left pulley, you will see it is spring loaded and easy to force the belt over if the right pulley is still on the jack. Really important to get the belt inside all the belt guides and lowering the deck before you frustrate yourself with getting the belt over the last pulley. When all is done, release the jack and everything tightens right up.
Mar 19, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere EZtrak Z225 Zero-Turn Riding Mower Logo
83 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
