Question about Shop Vac ShopVac 3 HP 2 Stage 10 Gallon--Automotive Wet/Dry Vacuum Vacuum
I have a Model QSH 30 Shop Vac. I need to find a new wall bracket. Any suggestions?
3 Suggested Answers
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
SOURCE: vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Posted on Aug 29, 2010
Shop vac doesn't work. Does my shop vac have a thermo fuse?
Contact the manufacturer of device. They may help you. If not, make sure that current is reaching the on/off switch and that the power is reaching the motor - if power gets to motor and still nada then the issue is probably with the brushes not making proper contact with the commutator.
Dec 23, 2016 | Shop Vac Vacuums
Bypass power switch
You should simply purchase and install a new switch. It's not safe to bypass the switch as when you do, the entire electrical load is placed on the wall prongs when you plug in or unplug the vacuum. Depending on the brand of vacuum, you can easily order parts and replace the switch at a nominal cost.
Nov 08, 2013 | Shop Vac Vacuums
Problem is system cuts off after 10-30 seconds. Is this a common problem?
It is if the motor overheats. Overheating can be caused by several things. Clogged pipes, hose, wands, or power nozzle, or a dirty filter are the most common.
First, disconnect the hose from the wands, plug the hose into the wall outlet, and check the suction. If it's weak or non-existent, there's probably a blockage in it. You can double check by dropping a coin in one end and lifting the hose until the coin drops out the other end. This can best be cleared by using a shop vac or air compressor to blow air through it from the wall end. Plug the shop vac hose into the exhaust port, with the other end in the wall end of the hose Turn on. If this doesn't clear it, you'll probably need to take it to a repair shop.
Visually check the wands. If clogged, simply push it out with a broom handle.
With the wand detached, drop a coin into the wand opening of the power nozzle. If it doesn't fall through, use a wooden spoon handle to push the clog back through toward the brush. Clear it from there.
Check the filter. Remove it and rinse thoroughly. Allow it to air dry thoroughly before reinstalling.
If none of these help, the vacuum needs to be taken to a repair shop for diagnosis and repair.
Jan 20, 2011 | Broan-NuTone CV850 Advantage Bagged...
I have an electrolux central vacuum in my house. My central vac hose has something stuck in it, I think, maybe a sock. I tried to put a long dryer wand down it but the hose is just too long. Does this need...
The best way to clear an obstruction is to blow it out by attaching the wall end to the exhaust of a shop vacuum, or using an air compressor.
You can try holding the wand end of the hose directly to the CV in port and turning the machine on. This provides essentially the same action as the previous method.
If neither of these work, try a combination of the two. Or using a shop vac, hold the wall end to the exhaust of the vacuum and the wand end to the in port of the shop vac. Turn shop vac on and the obstruction should come out.
Borrow a good strong shop vacuum if you need to.
If these methods fail, take it to an authorized Aerus Electrolux store and have the service tech try to clear it. Care must always be taken when trying to clear an obstuction with a long object, especially if it's pointed. I've seen many hoses that have shorted out and even caught fire due to the wiring accidentally being "nicked".
Jan 03, 2011 | Electrolux Central Vacuum
I have a shopvac model#86776-24. The toggle switch went bad and I'm looking for a replacement switch
I got a replacement switch at a local electronic supply store: Philmore Miniature Rocker Switch part number 30-043. Shop vac changed the switch recently to two push buttons from the old rocker style. This update works a lot better.
Oct 25, 2009 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Switches will not turn off unit. model #cv450w
If the switches on the hose will not turn off the vac you have a short in the wiring of the vac pipe system or a defective relay on the circuit board. Plug the vac in again without the hose and disconnect the thin low voltage wiring were it plugs into or screws onto the vac.
If the vac continues to run once disconnected from the low voltage circuit you have a defective relay in the vac itself. Some are circuit board mounted , others freestanding. To avoid a service call you can take the tank off the wall and take it to a pro shop or remove the top hosing if you are confident and check out the relay for a replacement part.
If the vac stops your issue is in the house. Has any painting been done or any inlets removed lately.. check that area first for a short at the inlet. Go back to any and all inlets and remove them one at a time checking the mounting screws and backing plates for loose wiring which is touching either the metal inner wall plate in the wall or a common screw . Test the vac as you go.
If this does not help, you will need to examine the wiring in the house , running along the pipe. Again if anything has been disturbed recently, near the vac, or near any piping that would be your first suspect area.
Post back to advise.
Oct 18, 2009 | Broan-NuTone CV350 Central Vacuum
Over heating?
it sounds like you need to replace the motor in it . thank you for using fixya
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Need new switch for Shopvac QSP Pro 10 gallon unit
I just went through the same problem with a Shop Vac. The switch is easy to replace but not easy to find. After removing the switch, I found a match made by Sigma Switches. They directed me to contact a local RV dealer and look in either their Coast Supply or Stag/Parkway Supply catalogs for the appropriate switch (an H2-28 in my case for a QPL45 Shop Vac). After ordering the switch and $5 later, it snaps in like the original with no problems. Certainly beats $70 for a whole new motor assembly.
Dec 28, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Shop Vac Model 758.17871
I would suggest it if it gets dirty muddy you can always clean the filter alot easier than replaceing vac
Dec 21, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac ShopVac 3 HP 2 Stage 10 Gallon--Automotive Wet/Dry Vacuum Vacuum Logo
105 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
