Question about Garden
What year is my ariens snowblower modle number 932020 st524
  • 133 Answers
SOURCE: I need the owners manual for an Ariens Snowblower
You might need to change the friction wheel. I looked up your model number and the part number for the friction disc is PN# 240394. You might be able to get the part locally from your small engine repair shop.
To replace the disc you will need to drain the oil and place some plastic over the gas tank and put the cap on so no gas will leak out. Then you will have tip the blower forward so it is setting on the augers.
Then remove the bolts on the access cover on underside . Once removed you will have to remove the wheel and see what else you will to remove. It is pretty easy to figure it out. If you have to take out the rod that moves the friction disc from side to side (gear shift rod) MAKE SURE IT IS IN PLACE AND WORKING BEFORE REASSEMBLING. Put in fresh oil and remove plastic. It should be up and running.
Good luck let me know if this helps.
roundo4
Posted on Aug 14, 2009
harlan301
  • 205 Answers
SOURCE: how do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Posted on Oct 12, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a 1984 ariens snowblower with a Tecumseh and no spark
Electronic Ignition was introduced on many engines about that time frame. I would need to have model and type numbers from the engine to fully determine that question. However, have spark is still the issue. If the unit has a switch installed on the operator's console, it should be disconnected at the engine so that any safety switches are not masking or causing a problem that is not engine related.
Let's investigate a few basics first.
a) How have you determined that there is no spark?
b) Have you used a type of spark tester?
c) What is the condition of the plug. Brown or dark brown is OK. Black or silver is NOT Ok.
*If you do not have a spark tester,
a) remove the plug, and with it connected to the wire,
b) find a portion of metal around the cylinder that you can ground it on, and then pull the rope.
c) If the plug is black, you may see spark, but you should replace the plug.
*** PLEASE NOTE ; if there is excess fuel in the cylinder or on spark plug, it can catch fire, so be carefull to cover the hole with a heavy rag so that any fuel cannot be exposed to spark plug durning test !!!!
Get back with me on how this issue works out.
thanks, rwvanlue
Posted on Nov 13, 2009
unvme
  • 266 Answers
SOURCE: My ariens st524 snoblower is
or build up in carb...... from old gas
Posted on Dec 27, 2010
Tech_Mate
  • 680 Answers
SOURCE: Ariens 8.5 HP snowblower, 5
First I would take out the spark plug then try tugging on the rope. If no success take a ratchet and a deep well socket that fits the nut on the flywheel tighten and loosen the nut with out restricting the flywheel does the engine turn over? Does it move then stop after you loosen the nut? If it does then check the oil. If it is low or none in there then the motor froze up and needs replacement. If this was no help check in the shoot for obstructions like a newspaper stuck in the auger or the thrower.
Terry
Posted on Jan 10, 2011
Need a carburetor for old Ariens snowblower. Number on carb is 510121 but can't find anywhere?????
Carb was probably bought in from a specialist manufacturer by the engine maker along with the ignition equipment and the maker of the snow blower in turn would have likely bought in the engines.
Few manufacturers bother making stuff for themselves when others can do it better and cheaper.
If you want it to be authentic I suggest you get in touch with Ariens with details and pictures of your snowblower and ask them if they have anyone there with a long white beard and a memory to match who could tell you where the carbs were sourced. It will be a matter of playing detective and following a line of clues.
If you aren't bothered about authenticity there are a number of generic replacement carbs that could be made to fit and jetted to suit and if it is a governed engine the governor could probably be made to fit too.
Feb 26, 2015 | Ariens Garden
Parts not available for Ariens ST724 7hp snow blower?
As far as the bolts you should be able to match them at a small engine and lawnmower repair shop and as well if you take the old recoil they might be able to get you what you need.
Nov 10, 2014 | Garden
Parts not available for Ariens ST724 snowblower?
No you do not..you have the model number and hp should do it ..go in on your computer and just put the name,model number,hp and model in that order .or better yet go in on eBay and put that in and most likely you will find it a a reduced cost..good luck
Nov 10, 2014 | Ariens Snowblower Belt 72098, 8hp 1/2 X 37...
I have an Ariens st524 model number 932020 that I recently acquired that has a leaky carberator and the gas shutoff doesn't shut completely so all of the gas just leaks out while the machine is in storage....
I think the leaking gas at your carb is caused by the float or inlet needle that controls the proper amount of gas going in the carb. If you remove the float bowl from the carb to get at the float, remove the float and check to see if there is gas inside inside the float by shaking it. The float is very light as you can see, so a little bit of gas inside makes it not control the gas level at the proper level. You can also wipe the float dry, then move it around and if there is gas in it you will see a wet spot. If leaking install new one. It could also be the inlet needle sticking and allowing too much gas to get in the bowl. When gas leaks out of the carb that way that is usualy the problem. I hope this helps you out a little. Best regards and good luck. I will gladly answer any questions.
Dec 25, 2010 | Garden
We are looking for the service manual for an Ariens snowblower Model 92001. I would like to print it from the computer.
Try printing from here. You'll need a model AND serial number
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=gsw0uz210g3q1n45lcz3mtig&site=arienss
Dec 28, 2009 | Garden
How do I change ariens snowblower belts
Oct 12, 2009 | Ariens Garden
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
