Question about Canon PowerShot S410 / IXUS 430 Digital Camera
Dropped camera and don't know if it is fixable
I dropped my camera and it is usually durable, but this time I got it right where the lens comes out and it is now crooked and won't retract. Therefore, when I turn the camera on it just keeps clicking on and repeating but it can't retract the lens so I can't download pictures or use it. Any idea if this can be fixed?
  • Canon Master
  • 4,738 Answers
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Try correction method #4 for your camera.
Posted on Nov 16, 2007
  • 641 Answers
Generally speaking, there is nothing you can do to correct the problem other than to send the camera to the appropriate factory service center for correction of the error. Following the repair cost you should decide, whether it worth it.
Posted on Aug 03, 2007
My sony 50mm 1.8 is not working in auto focus and grinds when I manually focus
Sorry, but this is not user-fixable.
If the lens has not been dropped or misused, then send it to Sony for repair, it may even be under warranty. If they find evidence of accidental damage or misuse then they will send you a repair estimate and you can decide whether to go ahead or to buy a replacement. You might decide to buy a used replacement, but bear in mind that there will be no warranty and you cannot absolutely know the usage history of that lens. Pre-owned Sony lenses and cameras are often not a good choice as they are built to keep costs down rather than for durability.
When you get the repaired lens back then test it thoroughly and use it very regularly for a few months. I have found that Sony official camera repairs are not always to the highest standard and if you uncover a faulty or careless repair a few months after they return it to you they usually try to wash their hands of the problem.
Sep 18, 2011 | Sony 50mm f18 Lens
Sony Cybershot DSCW350 - Camera got dropped with the lens out. While I was able to straighten it out, the lens will no longer completely close (although it clicks like it is trying to) and I continue to...
It seems that some small part inside the lens is broken and prevents moving. Usually not fixable by user :-( I am afraid you will need help of service personnel.
Jun 19, 2011 | Sony Cybershot DSCW350 Digital Camera
My camera was recently dropped, and now it shuts off at random times without retracting the lens. I am wondering if this is fixable, or if it is worth it. The camera was purchased for about $345 in 2007,...
Hi, its better you bring to service center and request for estimation first before they proceed to repair. Im am repairng Casio and Kodak digital camera and usually the damage parts are only gear which is very cheap. sometime only adjustment were doing as long all the parts inside of the lens are still ok .
thank you
Aug 10, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Lens won't come out or it comes part way out and goes right back.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 05, 2009 | Canon PowerShot A640 Digital Camera
Pictures turn out blurry..why?
One of the internal lens assemblies has probably come loose inside the lens. It happens often when the camera gets dropped. It requires major disassembly of the camera to get the lens unit out to work on it. Usually costs around $68.50 to fix.
Bob Kilbourn
www.CameraRepairs.com
Jun 28, 2009 | Canon PowerShot SX100 IS Digital Camera
I dropped my Exilim Z77 on the ground and now I have a lens error
the answer to that question is really up to you.  I'd try to repair it once again and if that failed, I'd go to Walmart and buy a new camera.
Apr 02, 2009 | Casio Exilim EX-Z57 Digital Camera
Camera dropped, lens won't retract or expand
You can buy a new A590 for under $110 these days, so the professional repair option may be out. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 24, 2009 | Canon PowerShot A590 IS Digital Camera
My daughters friend dropped her Olympus FE-340 camera when it was on. It must have fallen on the opened and extended lens because it looks like it has jammed the outer lens ring off to one side. Is...
You can try to pull the lens back into its socket, and it might work again for a while. Usually when the lens barrel is forced of track, something is broken in the process. Plan on installing a new lens.
Nov 13, 2008 | Cameras
Dropped Kodak Z740 lens won't open/close
This is not a simple fix
Indeed it may not be fixable
With so many new models coming on line all the time parts are usually available
Kodak Support will advise
Oct 28, 2007 | Kodak EasyShare Z740 Digital Camera
Stuck Lens
You will not fix it, the mechanism is not usually fixable If you take it apart ,you will then need the new camera.
Aug 04, 2007 | Fuji FinePix A700 Digital Camera
Canon PowerShot S410 / IXUS 430 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
