Question about Refrigerators
Fisher&paykel refrigerator model E331T with red light peeping continiuosly
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
  • 3230 Answers
SOURCE: Fisher & Paykel dishwasher model dd602 error code F4
It means your filter is dirty. Remove metal plate at bottom & scrub with a toothbrush. Clean arms as well.
Clean all around the door & pull out the lift out filter, scrub clean with a toothbrush.
Posted on Jun 26, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: Fisher & Paykel Dryer model ED56 constant beep
Diagnostic Mode
Entering the Diagnostic Mode
(a) Turn the power supply to the dryer on.
(b) Press and hold the Auto Dry down button, then press the Power
button.
The dryer is now in level 0 of the diagnostic mode. After initial entry into the
diagnostic mode, the Start/Pause button operates the dryer as normal. Press
the Auto Dry up or down buttons to scroll through the fault levels.
There are several levels of diagnostics, most of which are used in
development and production. These levels may bring on various LEDs, but
the level of use for the service technician is that of the last fault.
Last Fault
To enter the last fault diagnostics, enter the diagnostic mode as described
above, then press the Auto Dry up button three times. The last fault will be
displayed on the drying progress LEDs.
The manual is here
Posted on Sep 08, 2009
rylee_smith
  • 8619 Answers
SOURCE: I would like to receive
Hi
Thanks for using FixYa. Before you begin to replace your defrost thermostat, makesure you disconnect the appliance's power supply. The easiest way to do this isto unplug the unit from the wall. Alternatively, you could trip the appropriateswitch in the circuit breaker panel, or you could remove the appropriate fusefrom your home's fuse box.
Please check your refrigerator's defrost thermostat in this picture--
Click on the image to zoom in. It is located under the floor of the unit. The thermostat is wired in series with the defrost heater, and when thethermostat opens, the heater shuts off.
The cover plate over the coils needs to be removed. Now remove the freezer door, and then the screws so that each side of outer fridgecover is detached. This will to enable cover plate to slide out. (Outer walls have to be pried out alittle). Defrost thermostat is located behind coils.
Also check the Defrost Timer which is located at bottom offridge frame next to compressor. A couple of screws and unplug and plug in new part. There are two wires leading from the thermostat. They areattached to terminals with slip-on connectors. Gently pull on the connectors torelease the wires from the terminals. You may need to use needle nosed pliersto help you. Do not pull on the wires themselves.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 27, 2009
Fisher & Paykel ActiveSmart 517L Top Freezer E521TRX3 control panel lights blinking
Hello Ajay Gaddi...
Flashing panel...
I got NOTHING after reading several manuals
(seems to be a UK model... We have limited information here in the USA)...
Accept my apology and try these references
(as appropriate)
If after checking these points you still need assistance, please refer to your nearest
Fisher & Paykel Authorised Repairer, or contact us through our local website listed on the back cover.
In New Zealand if you need assistance...*
Call your Fisher & Paykel retailer who is trained to provide information on your appliance, or if we
can be of any further help, please contact our Customer Care Centre.
Toll Free: 0800 FP CARE or 0800 37 2273
Fax: (09) 273 0656
Email: customer.care@fp.co.nz
Postal address: Fisher & Paykel Appliances Ltd, PO Box 58732, Botany, Manukau 2163, Auckland.
If you need service...*
Fisher & Paykel has a network of independent Fisher & Paykel Authorised Repairers whose fully
trained technicians can carry out any service necessary on your appliance. Your dealer or our
Customer Care Centre can recommend a Fisher & Paykel Authorised Repairer in your area.
In Australia if you need assistance...*
Call the Fisher & Paykel Customer Care Centre and talk to one of our Customer Care Consultants.
Toll Free: 1300 650 590
Fax: (07) 3826 9298
Email: customer.care@fp.com.au
Postal address: Fisher & Paykel Appliances Ltd, P.O. Box 798, Cleveland, QLD 4163
Fisher & Paykel has a network of qualified Fisher & Paykel Authorised Repairers responsible for
servicing only Fisher & Paykel branded appliances. Our Customer Care Centre can recommend a
qualified Fisher & Paykel Authorised Repairer in your area.
In United Kingdom if you need assistance...*
Phone: (0845) 066 2200
Fax: (0845) 331 2360
Email: customer.care@fisherpaykel.co.uk
Postal address: Fisher & Paykel Appliances Ltd, Maidstone Road, Kingston, Milton Keynes,
Buckinghamshire, MK10 0BD
Aug 21, 2017 | Fisher Refrigerators
Fisher Paykel RF175WDRX1. Why does the fridge beep when I open it?
check the thermostat setting for the compartment
it may not be set low enough so the alarm goes off when the compartment temperature reaches or exceeds that setting
some fridges have a system whereby if the door is open too long then it notifies the user to close the door
May 21, 2015 | Fisher Paykel RF175WDRX1 Fisher & Paykel...
How to I change handing of fisher & paykel 2 door fridge
Hello friend
Not your machine but this is how it is done for standard Fridges , They are all similar http://www.youtube.com/watch?v=VEcPVbOjdUE
Extract From the fisher & paykel website user guide ....it seems to be all about the handles.
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/5339_NZ_AU_ActiveSmart__HR.pdf
Door conversion
If you need to hinge your door on the opposite side we recommend that you call your local
Fisher & Paykel Authorised Repairer or Dealer to make this conversion.
ActiveSmart refrigerator models with silver handles need to be ordered at the point of purchase either with left or right opening doors and can not be interchanged.
All other models need to have an appropriate conversion kit for that model refrigerator.
The kit is available from your Fisher & Paykel Authorised Repairer or Dealer. Full instructions are
included in the conversion kit.
This does not apply to French door mode
Sep 11, 2014 | Fisher and Paykel Refrigerators
Fisher paykel e381t
It is probably no more expensive than a CONTROL BOARD...
POSSIBLY as cheap as a door switch...
It is sensing a DOOR ALARM... and quite reasonably
stopping ... and alarming.
You need to find the PIZZA box, poor door alignment
or FAULTY circuitry that is causing the ALARM.
ELSE
Contact the maker for support
(on your back panel... or by reading your Owners Manual).
Like (example)...
Fisher Paykel E331T Installation Instructions And User Manual Page 44
Hope this helps
Carnac the Magnificent
Jul 28, 2017 | Fisher Refrigerators
I have a Fisher & Paykel Fridge Model E521T Serial # BSQ725303 The fridge is still working but it is making a groaning noise like the compressor is cutting in & out. Also the green & red...
Ah the evaporator fan is the noise.
Either the fan is hitting on built up ice or the bearings in the motor are worn.
If it is ice then you have a defrost problem and you will need a technician to help you there.
If it is the bearings you will need a new fan motor. Again a technician can help you
Mar 24, 2011 | Fisher and Paykel Refrigerators
My fridge Modle E331T is icing up in the freezer and then gets progressively warmer.
as the ice builds up, it acts like a insulator and it wont get cold, sounds like something wrong with the defrost cycle. let me know.
Feb 21, 2011 | Fisher and Paykel Active Smart® E522BR...
Hi There My Parents have a Fisher & Paykel (E331T) the Freezer is working fine, but the fridge where the dairy products sit don't seem to be freezing at all im not sure if there suppose to be a fan...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | Fisher and Paykel Active Smart® E522BR...
Fisher & paykel refrigerator n325t freezing up
how long it takes to form the ice in a frost free (fisher & Paykle) refregerator ?
Feb 25, 2010 | Fisher Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
